  #21
Old 10-03-2022, 04:20 PM
Eric Lambert's Avatar
Default Re: Anybody successfully using an HD Native TB/Omni with a Mac Studio?
Originally Posted by Tekzenmusic View Post
Hello, does anyone have any tips for getting my HD thunderbolt native to work with my Mac Studio M1 Max?
I've done the reduced security steps per this article https://avid.secure.force.com/pkb/ar...ation-on-macOS
However, it's not even showing up as connected under system report.
I'm using the cable it came with (although it does say DisplayPort cable on it) with the Apple thunderbolt connector. I've tried using a powered thunderbolt hub but no luck. I'm not getting any LEDs on the unit.
I'm on PT Ultimate 2022.9.0 & 12.3.1
You're using a TB3 to TB 2 adapter, something like this one?
https://www.apple.com/shop/product/M...D4595%252B401f
Which OS are you running?
Did you perform the task where you boot the computer into Recovery Mode, dial-back the security measures, then reinstall HD Drivers? My HD Thunderbolt box wouldn't show up either until I went through that step.
  #22
Old 10-04-2022, 11:31 AM
Tekzenmusic Tekzenmusic is offline
Hi Eric,
Yep that same one
12.3.1
yep.
EDIT: Working now, they had sent me a Displayport cable instead of thunderbolt, thanks for your help regardless!
  #23
Old 06-22-2023, 07:29 AM
Skytouch Skytouch is offline
Originally Posted by Darryl Ramm View Post
If he purchased upgrades through Sweetwater and should have purchased Ultimate I expect Sweetwater will fix this/make him whole.
Lots of choices out there with good USB interfaces that surpass the sound quality of Omni. But to me it would be that Ommi is nice but very limited I/O and if I was being annoyed about licensing I'd dump and run. And end up with a more capable interface.
Slightly off topic, I’m moving to Mac Studio and have Omni PCIe. Can you suggest specific interfaces that exceed Omni quality? I’ve considered Avid Mbox Studio but don’t know yet if this is comparable or a step down. Otherwise RME UFX III is a pricier consideration.
EDIT: I just found a few suggestions in your later post thanks.
Thanks,
Sky
(Opinions are my own, etc.)
Mac Studio M2 Max 12/30/64GB/4TB, RME UFX III, Pro Tools Ultimate, MacOS Ventura.
Anyone ever successfully restore firmware to an Omni scenaria Pro Tools HDX & HD Native Systems (Mac) 7 08-30-2021 06:09 PM
PT not seeing Omni (HD Native) 12.6.1 YumYumAudio Pro Tools HDX & HD Native Systems (Mac) 5 09-08-2017 09:31 AM
Who is Running PT 11 HD Native successfully K Roche Pro Tools HDX & HD Native Systems (Mac) 17 09-27-2013 12:02 PM
Pro Tools 10.2 HD Native on Mountain Lion, Successfully working! saproduction Pro Tools TDM Systems (Mac) 11 08-24-2012 02:32 PM
Has any1 successfully used FL Studio as a Plug-in? DeNiro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-13-2006 08:31 PM
