Old 08-10-2021, 08:11 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default checking plugs for version info
I'm pretty sure all the plugins I have were installed as 64bit. Is there and easy way to check this? as I'm thinking of updating my MacOS to Catalina 10.15.1
cheers in advance.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 08-10-2021, 09:07 PM
Sardi Sardi is offline
Default Re: checking plugs for version info
All AAX plugins are 64bit assuming you’re working in any version above 11.
If your concern is primarily plugins for use with PT, assuming you’re running 11 or higher, then you have no issue re: 64bit plugins.
Old 08-10-2021, 09:32 PM
xrekcor's Avatar
Thanks Sardi,
Yup they are all aax, ah ha now I remember…. Just been away from recording for a while and now updating everything.
Ver 11?… like Waves ver 11 their studio rack plug is ver 9 on my system everything else ver 11 with 1 that is ver 12.
Cheers
Rob
Old 08-10-2021, 10:24 PM
No. I mean v11 of PT.
PT10 introduced the AAX plugin architecture but it was 32bit as it had to coexist with RTAS/TDM. PT11 made the jump solely to AAX/AAX DSP which is all 64bit.
Old 08-10-2021, 10:32 PM
xrekcor's Avatar
Haha sorry man.
I want to up grade to Catalina coz I’m hearing the latest PT is pretty solid on Catalina
Rob
Old 08-11-2021, 12:16 AM
JFreak's Avatar
JFreak JFreak is online now
Darryl Ramm has a nice script for checking plugin versions here. Maybe one day it also optionally mentions bitness, but even version number tells you a lot.
Janne
Old 08-11-2021, 02:49 AM
Southsidemusic's Avatar
Originally Posted by xrekcor View Post
Haha sorry man.
Really REALLY Happy to see you here after a long time!
Hope all is well and you have a good music year after that pesky 2020
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 08-11-2021, 06:51 AM
Farhoof's Avatar
Farhoof Farhoof is offline
I've had some issues with plugins under Catalina. I don't remember if it's the installer (universal binary?) or the actual plugin. But even if you can run the plugin, not being able to install it is a hassle nonetheless.
In our case it was Penteo 7 on a rented dubstage running the latest Mac pro's. Had to run Penteo 16 instead which was no problem. I didn't test just copying the .aaxplugin file to the plugin folder.
Old 08-11-2021, 04:55 PM
smurfyou smurfyou is offline
That is a Penteo issue. I ran into the same thing. They told me Penteo 7 wouldn't be compatible on Catalina and above. It was some kind of 64/32 bit universal binary apparently.
~Will
Old 08-12-2021, 12:05 AM
xrekcor's Avatar
Thanks mate! I’ll check that out
Rob
HTML code is On
Session 8 for mac info, version 2.0 and 882 Studio blackmacdaddy Digidesign Hardware & Software 5 07-03-2020 12:32 PM
Version 8.0 Plugs with 7.4? emorganproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-10-2009 06:49 AM
Where can I find the latest version info? NinjaBob Pro Tools TDM Systems (Mac) 1 07-10-2002 02:20 AM
Where can I find info about how much dsp power different plugs uses? ed hamilton Pro Tools TDM Systems (Mac) 2 04-26-2001 11:41 AM
Windows version info please!! NOPRO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-03-2000 03:22 AM
