Old 06-29-2021, 02:22 PM
the.engineer the.engineer is offline
Default Colours are different in 2021.6
Does anyone else, like me, have their channel strip fully coloured? I can't stand it being grey and I have a very strict colour system that allows to me navigate my mixes easily.
2021.6 is very different and the subtleties between the colours seem to have gone.
Can anyone else confirm this and/or is irked by it?
What say you Avid? Can we go back to how it was?
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 06-29-2021, 02:58 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: 2021.6 Colours are different
The legacy settings (saturation and brightness) for track headers don't map perfectly to updates we made for UI Customization. This is due to the wider range of adjustments that are now possible. What you'll want to do is manually make those adjustments in Window > Color Palette > UI Customization to get it close to what you're used to. These UI settings are system based, so you only need to adjust them once.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 06-29-2021, 03:16 PM
Thanks Kyle for getting back so fast. I did have a play around (albeit for only 2 mins) and couldn't get to where I wanted it, however...
I'll have another go!
James Welch
Old 06-29-2021, 05:51 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
When you say system based, does it mean that they are stored with the Pro Tools Preferences File, or somewhere else?
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 06-30-2021, 02:47 AM
mbuz mbuz is offline
Windows 10 Pro here and I confirm the difference with track colors on new PT2021.6.
I am not able to have the same color setting as before and there are less colors availability on the track header.
This could be quite confusing when mixing with a lot of tracks.
Marco Buzz
Old 06-30-2021, 07:53 AM
BScout BScout is offline
"there are less colors availability on the track header"
This isn't true. The grid of colours is the same size as previous versions.
Just the shade/saturation is slightly different
Old 06-30-2021, 09:02 AM
devinemke's Avatar
devinemke devinemke is offline
i can corroborate this issue. see attached screen shot. at the bottom of the mix window you can see that the left side tracks are a different shade of red compared to the right side tracks. but the background color of all of the tracks looks the same. definitely a change from previous PT versions before 2021.6. as Kyle said, i gather this due to the mapping of the old color palette to the new.
Devin Emke
Audio Post Production
Saturday Night Live, NBC
Old 06-30-2021, 12:36 PM
Hi Edgar,
They are saved in the Pro Tools Presets > Color Palette folder.
Kyle Splittgerber
Berkeley, CA
Old 06-30-2021, 12:49 PM
Eric Lambert's Avatar
Hi Edgar,
Question then: if I delete the PT Prefs file (as I do at times), will I lose the color settings? And if so, can I retrieve them after deleting Prefs by importing from the Color Palette folder?
Old 06-30-2021, 01:43 PM
Trashing prefs will default colors. Best to actually save your settings(not just assign to one of the preset buttons).
2021.6 and 2021.7 restart after exit NJsound.com Pro Tools 12 08-11-2021 01:45 PM
2021.6 colours? midnightrambler Pro Tools 6 07-29-2021 08:47 AM
Clip colours Reckless Erik Pro Tools 2018 0 03-07-2018 06:50 AM
Memory Colours? Neurosis Pro Tools 12 2 06-12-2016 10:59 AM
