Old 11-02-2019, 10:57 AM
Jasconito Jasconito is offline
Default Getting "Access violation occurred-unable to read location" error in 2019.10
Hello all,
It's been eons since I've had any issues with my system until of course this AM for me...
Just upgraded to 2019.10 this AM and started getting "Access violation occurred-unable to read location" error...Not sure what happened, but because of this, I can't open PT...I'm guessing this has something to do with the Xpand!2 plug-in - see attached screenshot, splash page keeps freezing up whenever PT tries to find it...
Here's what I've done thus far:
1) Reinstalled PT2019.10 (twice), even went down 2019.06 - get the same error
2) Reinstalled Xpand!2 2018.10, still get the same error
3) Trashed preferences repeatedly, did nothing
4) Checked the plug-in folder, (C:/Program Files/ Common Files/ Avid/ Audio/ Plug-ins) Xpand!2 is where it should be or is that not the case? I have not deleted it...Should I?
Simply put I'm out of ideas and the forums only say so much about this. Hoping someone can throw out an idea or 2...Appreciate it...Thanks in advance!
System specs if you need it:
Computer
Model : GigaByte Z270X-Gaming 7 Default string
Serial Number : Default*******
Chassis : Default string Desktop
Mainboard : GigaByte Z270X-Gaming 7
BIOS : AMI (OEM) F7 07/06/2017
Intel vPro : 11.06.27.3264
Total Memory : 32GB DIMM
Processors
Processor : Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz (4C 8T 4.5GHz, 4.5GHz IMC, 4x 256kB L2, 8MB L3)
Chipset
Memory Controller : 7448 RME Fireface UFX+ 100MHz, 32GB DIMM 2.13GHz
Memory Module(s)
Memory Module : Fujitsu F4-3200C16-16GVK 16GB PC34100U
Video System
Monitor/Panel : Toshiba TSB-TV
(1920x1080, 32.0")
Monitor/Panel : AOC International 1659W (1600x1200, 15.3")
Video Adapter : NVIDIA GeForce GTX 1060 3GB (9CU 1152SP SM5.2 1.6GHz/2GHz, 1.5MB L2, 2.9GB 8GHz 192-bit, PCIe 3.00 x16)
Video Adapter : DisplayLink USB Device (9CU 1152SP SM5.2 1.6GHz/2GHz, 1.5MB L2, 2.9GB 7.6GHz/8GHz 192-bit, PCIe 3.00 x16)
Graphics Processor
CUDA GP Processor : NVIDIA GeForce GTX 1060 3GB (1152SP 9C 1.6GHz/2GHz, 1.5MB L2, 3GB 7.6GHz/8GHz 192-bit)
OpenCL GP Processor : NVIDIA GeForce GTX 1060 3GB (9SP 9C 1.6GHz/2GHz, 144kB L2, 3GB 7.6GHz/8GHz 192-bit)
Compute Shader Processor : NVIDIA GeForce GTX 1060 3GB (1152SP 9C 1.6GHz/2GHz, 1.5MB L2, 3GB 7.6GHz/8GHz 192-bit)
Compute Shader Processor : Microsoft Basic Render Driver (16GB)
OpenGL Processor : GeForce GTX 1060 3GB/PCIe/SSE2 (3GB)
Storage Devices
Samsung SSD 850 EVO 250GB (250GB, SATA600, 2.5", SSD, SED) : 233GB (D:)
Samsung SSD 860 EVO 500GB (500.1GB, SATA600, 2.5", SSD, SED) : 466GB (F:)
Samsung SSD 850 EVO 500GB (500.1GB, SATA600, SSD, SED) : 466GB (C:)
WDC WD1001FALS-41Y6A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (E:)
Samsung Portable SSD T5 (250GB, USB3/SATA600, mSATA, SSD, SED) : 233GB (G:)
SMI Feiya Technology Memory Bar (31.5GB, USB3) : 29GB (H:)
Logical Storage Devices
Pro Tools Main (D:) : 233GB (NTFS, 4kB) @ Samsung SSD 850 EVO 250GB (250GB, SATA600, 2.5", SSD, SED)
SD3 (F:) : 466GB (NTFS, 4kB) @ Samsung SSD 860 EVO 500GB (500.1GB, SATA600, 2.5", SSD, SED)
Main OS (C:) : 465GB (NTFS, 4kB) @ Samsung SSD 850 EVO 500GB (500.1GB, SATA600, SSD, SED)
Pro Tools Back-Up (E:) : 932GB (NTFS, 4kB) @ WDC WD1001FALS-41Y6A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
EXT (G:) : 233GB (exFAT, 128kB) @ Samsung Portable SSD T5 (250GB, USB3/SATA600, mSATA, SSD, SED)
LICENSES (H:) : 29GB (FAT32, 16kB) @ SMI Feiya Technology Memory Bar (31.5GB, USB3)
Hard Disk : 849MB (NTFS, 4kB) @ Samsung SSD 850 EVO 500GB (500.1GB, SATA600, SSD, SED)
Peripherals
LPC Hub Controller 1 : Gigabyte Intel(R) 200 Series Chipset Family LPC Controller (Z270) - A2C5
LPC Legacy Controller 1 : T2 86-86
Audio Device : Gigabyte High Definition Audio Controller
Audio Codec : Creative Labs 0011
Audio Codec : nVidia nForce MCP2S PCI System Management
Disk Controller : Gigabyte Standard SATA AHCI Controller
Disk Controller : Gigabyte Intel(R) 200 Series Chipset Family PMC - A2A1
USB Controller 1 : Gigabyte Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
USB Controller 2 : Renesas Tech uPD720202 USB 3.0 Host Controller
USB Controller 3 : 8738 Intel(R) USB 3.1 eXtensible Host Controller - 1.10 (Microsoft)
USB Controller 4 : Fresco Logic FL1100 USB 3.0 Host Controller
Printers and Faxes
Printer : Microsoft Print To PDF (600x600, Colour)
Printer : Foxit Reader PDF Printer Driver (600x600, Colour)
Peripherals
Media Player : Samsung Portable SSD T5 (232.87GB)
Media Player : SMI USB DISK (29.28GB)
Network Services
Network Adapter : Killer E2500 Gigabit Ethernet Controller (Ethernet)
Network Adapter : Intel(R) Ethernet Connection (2) I219-V (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 10 Professional 10.00.17134
Platform Compliance : x64
SELF BUILT PC: WINDOWS 10 (64-BIT), INTEL I7-7700K CPU @ 4.20GHZ, 32 GB RAM
INTERFACE: RME FIREFACE UFX+, ELEVEN RACK
PRO TOOLS: PT2019.10
Old 11-02-2019, 02:17 PM
deanrichard deanrichard is offline
Default Re: Getting "Access violation occurred-unable to read location" error in 2019.10
Have you tried running PT as an administrator? I'm not sure how that works in Win 10, but in Win 7, IIRC right click the start icon and go into the Advanced tab.
Old 11-02-2019, 04:02 PM
Yep, did that as well, still had the same problem...Sorry, I forgot to mention that earlier...
Old 11-03-2019, 01:59 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Try moving Xpand 2 plugin from your plugins folder to the unused plugins folder. If you start PT after that and it starts as expected, you can quit PT and add Xpand 2 back to your plugins folder and it should work. If you start PT after removing the Xpand 2 plugin and there's another plugin trying to load that would have been after Xpand 2 and you get the same error message, you need to remove all plugins that would have normally loaded after Xpand 2 to your unused plugins folder. Start PT and let it load, quit PT and add them plugins you moved to your unused plugins folder back to your plugins folder and all should be fine. PT will only load so many plugins when first installed or you clear your plugin data base. This sounds like what I use to go through til I purchsed the Pro Tools Trasher app.
Sent from my SM-N976V using Tapatalk
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Meaning of: "Access violation occurred, unable to read location: 0x0000000000000368" taylor4814 Pro Tools 2019 3 06-09-2019 04:17 AM
Access violation occurred, unable to read location JasperEads Pro Tools 11 6 10-10-2017 01:16 PM
Access violation occurred, unable to read location: 0x0000000000000008 timcat Pro Tools Express on Windows 0 10-09-2017 01:21 PM
Access Violation occurred, unable to read location: 0x00000000 jham14 Pro Tools 10 2 08-09-2015 04:39 PM
Help with Pro Tools "Access violation occurred unable to read dll" issue dfeeley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-16-2011 09:01 PM
