Mix System Configuration Q's
I'm trying to find the most current Mix System Mac and Pro Tools configuration list.....
Can't seem to find anything specific (General Troubleshooting is pretty general and doesn't cover these things): Mac settings, such as power save settings (I'm sure mine are right), Display settings, memory settings, etc. Pro Tools settings..... etc. I've seen entire lists for other stuff, but the last list I saw didn't seem to be 'up to date' for mix. Was showing allocating 30-50 MB or some crap for memory for something, based on 128 or 256 MB of Ram.... LOL Little old? Anyone know where I can find this? This is the one I found, but not sure if it's 'current' to Mix systems. 1. What are the optimum settings for Pro Tools on a Mac? Appearance Control Panel:
Memory Allocation (Basic settings, based on 128-196 mb of RAM):
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
Re: Mix System Configuration Q's
Those guidelines are still valid on systems before OSX.
Just go for it.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
How much RAM does the CPU hosting your Mix system have? The more, the merrier — you should have at least 1GB, for optimum performance.
When entering RAM allocations for PT and DAE applications (in fact, for all apps) use values that are multiples of 1024 (i.e. 30,720 MB instead of 30,000). If you use your system for more than just running ProTools, see if you can get hold of Conflict Catcher, a great utility that allows you to administer system resources (such as extensions, control panels, fonts, etc.) with far more control and flexibility than Apple’s Extension Manager. CC also allows you to assign keyboard shortcuts to invoke different sets at startup, which is a big time saver. While you’re at it, get yourself a copy of Disk Warrior, which was indispensable back in the days of OS8 as it remains now. IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
http://en.wikipedia.org/wiki/Conflict_Catcher |
Oh yeah, to answer the original question, this list is correct for OS9, up to PT 5.1.3. Most of this stuff doesn't apply anymore with OSX.
The biggest caveats for your config are making sure not to go past quicktime 6.5.2. The second post on this thread covers pretty much everything you need to know for OSX: http://www.gearslutz.com/board/music...nce-audio.html I don't think the matched RAM matters on mdd g4's, it's more of an intel mac thing. |
thnx again john.
I'll give it a look later and print it out! I was just remembering that tweaking the OS and changing display settings etc helped performance tremendously on my XP machine. Obviously XP and OS are vastly different, but I did notice the OS list instructing to turn off 'font smoothing' or whatever. A change also recommended in XP, so I figured it's benefitial to make recommended changes on OS.
think of it as an old car
you have to keep them tuned up i have a G4 DP 1gig 1gig RAM mix+ OS 9 and 10.3.9 PT 5.11 and PT 6.4.1 mostly just Pro tools on this system I use it everyday...never crashes! |
can anyone help me re: system configuration | Deni | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-30-2009 02:59 PM |
New System Configuration | rokkit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-14-2008 12:32 PM |
Mix system, best configuration? | stargazer | Pro Tools TDM Systems (Mac) | 4 | 05-13-2003 10:28 PM |
System Configuration | Mitmont | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-20-2002 05:46 PM |
will this configuration/system work? | loserfriendly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-14-2001 02:38 PM |
