#31
Re: BAD_POOL_CALLER
Pro Tools LE 6.7 upgrade info here. In terms of SP2 compatibility, the upgrade is the same as 6.4 CS9. Hope this helps, Digidesign Technical Support |
#32
Re: Problems with PTLE? Post your configuration here..
see this thread: http://duc.digidesign.com/showflat.p...=&fpart=2&vc=1 not the same chipset, but also this thread: http://duc.digidesign.com/showflat.p...fpart=1#775794 regards, Digidesign Technical Support |
#33
To voysit and neeel,
Please confirm if the DAE errors still occur in diagnostic startup mode. We posted instructions on how to enable diagnostic startup mode in the first page of this thread. thanks, Digidesign Technical Support |
#34
SiSoftware Sandra
System Manufacturer : Dell Computer Corporation Model : Dimension 8300 Serial Number : 1HZLM31 ID : 4C4C4544-5A100048-C0B14C80-31334D4F System Chassis Manufacturer : Dell Computer Corporation Type : Mini Tower Can be locked : No Serial Number : 1HZLM31 Boot-up State : Safe Power State : Safe Thermal State : Safe Security State : External Interface Locked-out Mainboard Manufacturer : Dell Computer Corp. MP Support : 1 CPU(s) MPS Version : 1.40 Model : 0M2035 Serial Number : ..CN4811137D03R0. On-board Devices Intel Pro 100 VE Network Connection : Ethernet Adapter (Enabled) AC'97 Audio Controller : Sound Adapter (Disabled) System Memory Controller Location : Mainboard Error Correction Capability : ECC Number of Memory Slots : 4 Maximum Installable Memory : 4GB Bank 1 - CHANNEL A DIMM 0 : DIMM Synchronous SDRAM 256MB/64 @ 400Mt/s Bank 2 - CHANNEL B DIMM 0 : DIMM Synchronous SDRAM 256MB/64 @ 400Mt/s Bank 3 - CHANNEL A DIMM 1 : Empty Bank 4 - CHANNEL B DIMM 1 : Empty Chipset 1 Model : Dell Computer Corp 82875P,E7210 Memory Controller Hub Bus(es) : X-Bus AGP PCI IMB USB FireWire/1394 i2c/SMBus Front Side Bus Speed : 4x 200MHz (800MHz data rate) Maximum FSB Speed / Max Memory Speed : 4x 200MHz / 2x 200MHz Width : 64-bit IO Queue Depth : 12 request(s) Chipset 1 Hub Interface Type : Hub-Interface Version : 1.50 Number of Ports : 3 Width : 8-bit Full Duplex : Yes Multiplier : 1/1x Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR-SDRAM 3.0-3-3-8 1CMD Channels : 2 Speed : 2x 200MHz (400MHz data rate) Multiplier : 1/1x Width : 64-bit Refresh Rate : 7.80µs Performance Acceleration Technology : Yes Power Save Mode : No Fixed Hole Present : No APIC 1 Version : 2.00 Multiplier : 1/2x Maximum Interrupts : 24 IRQ Handler Engaged : Yes Enhanced Support : Yes Memory Module 1 Model : EBD25UC8AKFA-5B Extended Information : K Serial Number : 71010CCD Type : 256MB DDR-SDRAM Technology : 8x(32Mx8) Speed : PC3200U 3.0-3-3-8 Date of Manufacture : Wednesday, August 13, 2003 Set Timing @ 200MHz : 3.0-3-3-8 Set Timing @ 167MHz : 2.5-3-3-7 Set Timing @ 133MHz : 2.0-2-2-5 Memory Module 2 Model : EBD25UC8AKFA-5B Extended Information : K Serial Number : 71010CCA Type : 256MB DDR-SDRAM Technology : 8x(32Mx8) Speed : PC3200U 3.0-3-3-8 Date of Manufacture : Wednesday, August 13, 2003 Set Timing @ 200MHz : 3.0-3-3-8 Set Timing @ 167MHz : 2.5-3-3-7 Set Timing @ 133MHz : 2.0-2-2-5 Cooling Device(s) Fan : OK AGP Bus(es) on Hub 1 Version : 3.00 Speed : 4x Multiplier : 1/2x Fast-Writes Enabled : No Fast-Writes Support : Yes Isochronous Mode Enabled : No Addressing Enabled : 32-bit Aperture Size : 128MB PCI Bus(es) on Hub 1 Version : 2.20 Number of Bridges : 2 PCI Bus 0 : PCI (1/1x PCIClk) PCI Bus 2 : PCI (1/1x PCIClk) LPC Hub Controller 1 Model : Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge ACPI Power Management Enabled : Yes Delayed Transaction Enabled : Yes LPC Legacy Controller 1 Type : SMSC LPC v1 Version : 14.04 Number of Enabled Devices : 4 USB Controller 1 Model : Dell Computer Corp 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 2 Model : Dell Computer Corp 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 3 Model : Dell Computer Corp 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 4 Model : Dell Computer Corp 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 5 Model : Dell Computer Corp 82801EB/ER (ICH5/ICH5R) USB 2.0 EHCI Controller Version : 2.00 Specification : 1.00 Interface : EHCI Channels : 8 Companion Controllers : 4 Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support : 64-bit Legacy Emulation Enabled : No FireWire/1394 Controller 1 Model : Creative Labs Audigy 2 Firewire Controller Version : 1.10 Interface : OHCI Enhanced Support : No Channels : 64 Speed : 400MHz System SMBus Controller 1 Model : Intel 801xx/63xx SMBus Version : 0.02 Specification : 2.00 Advanced TCO Mode Enabled : No Slave Device Enabled : Yes PEC Support : No Speed : 100kHz Expansion Slot(s) PCI1 (1h) : PCI 32-bit +5V +3.3V PME Full-Length Available (Intel Corporation 82875P PCI to AGP Bridge) PCI2 (2h) : PCI 32-bit +5V +3.3V PME Full-Length Available PCI3 (3h) : PCI 32-bit +5V +3.3V PME Full-Length Available PCI4 (4h) : PCI 32-bit +5V +3.3V PME Full-Length Available AGP1 : AGP-8x 32-bit +3.3V PME Full-Length Used Port Connector PARALLEL : Parallel Port PS/2 - None / DB-25 pin female SERIAL1 : Serial Port 16550A - None / DB-9 pin male KYBD : Keyboard - None / PS/2 MOUSE : Mouse - None / PS/2 USB1 : USB - None / USB USB2 : USB - None / USB USB3 : USB - None / USB USB4 : USB - None / USB USB5 : USB - None / USB USB6 : USB - None / USB USB7 : USB - None / USB USB8 : USB - None / USB ENET : Network - None / RJ-45 MIC : Audio - None / Mini-jack LINE-OUT : Audio - None / Mini-jack LINE-OUT : Audio - None / Mini-jack LINE-OUT : Audio - None / Mini-jack LINE-IN : Audio - None / Mini-jack HP-OUT : Audio - None / Mini-jack Performance Tips Notice 224 : SMBIOS/DMI information may be inaccurate. Tip 2511 : Some memory slots are free so the memory can be easily upgraded. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. My digi 002 rack keeps shutting off on me. I cannot use any of the buttons. The 1394 and sample rate lighs also flicker on and off. I can use my 002 and thus pro tools for only about a max of 15 minutes before this problem occurs again.
www.mcgowansoundworks.com |
#35
Hey Ducky,
We reproduced your Strip Silence bug in-house. This is the first step in getting it fixed. Thanks for the solid recipe. -rj Digi ETS |
#36
Hey PhilyG
This sounds like a hardware problem with your 002R, not your Dell machine. Please give CS a buzz for help. -rj Digi ETS |
#37
That fixed it. PT runs seemless even with network enabled. What a relief! Thanx a lot. Maybe this should appear in the answerbase. Kind regards Achim
HD2 Mac Pro Quadcore OS X 10.5.6 PT 8.0 |
#38
Well, how about my problem???? i did tell ya everything... and i can't write the sisandra test down...cause the CPU is completly by the TechSuport in Chile!!!!!
Powerbook 12" 1,5Ghz 1,25Gb RAM M-Box v.1.0 "the old one" PTLE 7.0 Tiger(10.4.6) Ministack v2 NEWERTECH FIREWIRE+SEAGATE 320Gb |
#39
best regards, Digidesign Technical Support |
#40
This made not a lick of difference. As I mentioned before, my performance is just bearable. However, I can only achieve 24 Tracks on the Davec test (not sure if this is digi sanctioned but seems to be the standard around here) compareed with 32+20 or so from the AMD folk among us. In addition I can and sometimes get sporadic 9094 and 9093 errors yet to date I have not been able to detect a steady pattern. I am going to buy another drive as a matter of course. This will be then dedicated to audio instead of the partition arrangment I have at the moment. I am hoping for an increase in performance from this. I have posted my system specs below. Any help is appreciated. SiSoftware Sandra System Host Name : NEIL User : Sessions Domain : MSHOME Processor Model : Intel(R) Pentium(R) 4 CPU 3.00GHz Speed : 2.99GHz Performance Rating : PR3981 (estimated) SMT Support : 2 Unit(s) Type : Standard L2 On-board Cache : 512kB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector Mainboard Bus(es) : AGP PCI IMB USB FireWire/1394 i2c/SMBus MP Support : 1 CPU(s) MP APIC : Yes System BIOS : Intel Corp. RL86510A.86A.0058.P08.0307151556 Mainboard : Intel Corporation D865PERL Total Memory : 1023MB DDR-SDRAM Chipset 1 Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Front Side Bus Speed : 4x 200MHz (800MHz data rate) Total Memory : 1GB DDR-SDRAM Memory Bus Speed : 2x 200MHz (400MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : RADEON 7000 SERIES Physical Storage Devices Hard Disk : ST3120026AS (112GB) CD-ROM/DVD : DVDRW IDE1008 (CD 40X Rd, 40X Wr) (DVD 5X Rd, 5X Wr) CD-ROM/DVD : OPTORITE CD-RW CW5201 (CD 52X Rd, 52X Wr) Logical Storage Devices system (C:) : 15GB (8.1GB, 55% Free Space) (NTFS) Sessions (D:) : 9.8GB (4.6GB, 47% Free Space) (FAT32) data (E:) : 87GB (53GB, 61% Free Space) (NTFS) CD-ROM/DVD (F:) : N/A CD-ROM/DVD (G:) : N/A Peripherals USB Controller/Hub : Intel(R) 82801EB USB Universal Host Controller - 24D2 USB Controller/Hub : Intel(R) 82801EB USB Universal Host Controller - 24D4 USB Controller/Hub : Intel(R) 82801EB USB Universal Host Controller - 24D7 USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : Intel(R) 82801EB USB Universal Host Controller - 24DE USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Microsoft PS/2 Mouse MultiMedia Device(s) Device : M-Audio Delta Audiophile Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Home (Win32 x86) 5.01.2600 (Service Pack 2) Network Services Network Drivers Enabled : No Thanks in advance for your help. neeel.
MBOX MINI PTLE 8.0.3 MAC OSX Snow Leopard Mac Mini 1.5Ghz Intel 2 Gig RAM ******************* |
Problems with PTLE? Post your configuration here...... | still_life_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-30-2007 12:27 AM |
Problems with PTLE? Post your configuration here.. | DJ John | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-28-2007 10:06 AM |
Problems with PTLE? Post your configuration he | krsongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-28-2007 09:59 AM |
Problems with PTLE? Post your configuration here.. | p3tch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-28-2007 09:46 AM |
Problems with PTLE? Post your configuration here.. | Gaba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-23-2007 08:01 AM |
