Old 11-25-2002, 10:26 AM
EDurney EDurney is offline
Default still getting -9093 errors...
I`ve been trying to fix this problem from more like a year now,i work with a 128 buffer setting all the time, and i don`t want to raise this to 256 because of the latency problem (low latency monitoring limits everything..you know)
and when i have a "high density" session i got this error.
i have already change my ide drivers to the standard ones, and i bought a Promise Ultra133TX2
PCI Ide controller...and the problem is not fixed.
My PC specs:
XP Pro
ATHLON XP 1800+
Asus A7V333 Mobo
256ddr Ram
80G 7200 Ulta ata 133 HD (3 partitions)the seond one is just for audio.
I dont have the problem when i hit play just when i record and not all the time just 50% of the time, i just need to fix this problem....
CAN ANYBODY HELP ME!!!!!!
(Please!?) [img]images/icons/frown.gif[/img]
(Last year i tried with two drives, you know, 1 for XP system and the other for audio on each ide channel and evrything was the same.)
Pro Tools 10 / Duet 2 - Eleven Rack - Mbox 2 pro
MacBook Pro 2.2ghz Quad Core/ 8gb RAM/ 750HD
Pro Tools 9 HD / 192io / C24
Mac Pro Quad 2.66 / 8Gb Ram
Old 11-25-2002, 03:17 PM
Carbon111 Carbon111 is offline
Default Re: still getting -9093 errors...
You really need more ram for that setup. Check the compat docs - I think 384mb is the bare recommended minimum:
http://www.digidesign.com/compato/maindigi001win.html
Regards, James
Old 11-25-2002, 05:34 PM
I Think that this problem is not related to Ram,
Anybody knows something about this??....
Allen??? [img]images/icons/frown.gif[/img]
Old 11-26-2002, 07:23 AM
bstaley bstaley is offline
If you have one harddrive split into three partitions it will actually perform worse with ProTools than if you had left everything as one partition. You really need to get a separate, dedicated, 7200RPM drive and dedicate that for audio. That should help immensely.
LANPARTY UT nF3 250GB RT
Athlon 3400 DTR
G.SKILL 1G(512X2) F1-3200DSU2-1GBLC
ZALMAN CNPS7000B-CU RT
EnerMax EG365P-VE FMA 1.3 RT
GeForce2MX
Old 11-26-2002, 10:09 AM
secars secars is offline
Upgrade to 512 ram. It's the best $100 investment you can make in your Pro Tools rig. It has a good chance of fixing this problem. Anyone running PT on 256 is making their lives harder than it has to be. Remeber when we say 256 is the minimum we mean minimum. You say you have "high density" sessions.
Sean Carson
Software Test Engineer
Digidesign
Old 11-26-2002, 11:05 AM
Jorge442 Jorge442 is offline
viste???
lo mismo que te han dicho caleta de veces!!
compra mas RAM!!
y un disco duro especialmente para tu audio
Lo único que voy a añadir es que no compres en REFLY porque venden puras wuevadas de 2a calidad.
buena suerte compadre y hágale caso al socio de Digi.
jorge
what a long, strange trip it´s been
www.abacomusic.com
Old 11-26-2002, 06:03 PM
Thanks for the reply guys.....well....it seems that i need 512......
(asi que refly es de 2da??? Jorge 442.....eso habia escuchado.....me puedes explicar por que??? [img]images/icons/rolleyes.gif[/img]
Old 11-27-2002, 09:33 AM
<font size="2" face="Verdana, Arial">REFLY vende más barato, por eso fuí para allá. Pero de los 3 discos duros que compré (western digital, Quantum, Maxtor) 2 me salieron malos! O sea fallaron despues de algunos meses de uso. Te imaginas los problemas que esto me ha causado!
gasta un poquito mas y compra en otro lado.
Te cuento que he terminado los projectos que me encontraba haciendo y me gustaria que nos juntaramos para conocernos, ¨protoolear¨ ,en fin, a lo mejor nos podemos ayudar el uno al otro.
Me diste tu numero y yo lo guardé en mi celular, pero me lo robaron...........escríbeme.
saludos
jorge
www.abacomusic.com
Old 11-28-2002, 11:45 AM
ok, me compre otro celular:
09-890-5804
saludos!
ps: qué le está pasando al wanderito??
www.abacomusic.com
HW Buffer errors and Mass Confusion! 9093 Errors!! guitarlancer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-08-2007 10:38 AM
(-9129) and (-9093) errors no more! ANTDEM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-17-2006 11:11 PM
-9093 same old errors and I've tried EVERYTHING unclecolly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-19-2006 12:02 AM
Errors 9093 and 9129 almendra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-30-2005 01:23 AM
still getting -9093 errors stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-09-2002 10:33 PM
