Old 03-10-2006, 12:13 PM
unclecolly unclecolly is offline
Default -9093 same old errors and I\'ve tried EVERYTHING
ok maybe not everything, but I've been reading all the forums on people with the same -9093 increase buffer size then another error when I increase the buffer size, and trying all of the suggestions, so I thought perhaps I have a hardware problem that is the root. Here is my configuration from sandra, I hope someone can put an end to my misery
Could this problem be related to the fact that I have a USB 2.0 external audio drive and not firewire?
SiSoftware Sandra
System
Host Name : COLINPROTOOLS
User : Owner
Domain : WORKGROUP
Processor
Model : 1x AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Speed : 2.00GHz
Model Number : 3800 (estimated)
Performance Rating : PR6012 (estimated)
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Internal Data Cache : 2x 64kB Synchronous, Write-Back, 2-way set, 64 byte line size
L2 On-board Cache : 2x 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Bus(es) : ISA PCI PCIe USB FireWire/1394
MP Support : 2 Processor(s)
MP APIC : No
System BIOS : Phoenix Technologies, LTD 6.00 PG
System : Gateway GT5028
Mainboard : C51MCP51
Total Memory : 895MB DDR-SDRAM
Chipset 1
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Front Side Bus Speed : 2x 1000MHz (2000MHz data rate)
Total Memory : 1GB DDR-SDRAM
Memory Bus Speed : 2x 200MHz (400MHz data rate)
Video System
Monitor/Panel : Plug and Play Monitor
Adapter : NVIDIA GeForce 6100
Physical Storage Devices
Hard Disk : ST3250823A (233GB)
Hard Disk : Generic USB CF Reader USB Device
Hard Disk : Generic USB MS Reader USB Device
Hard Disk : Generic USB SD Reader USB Device
Hard Disk : Generic USB SM Reader USB Device
Hard Disk : WDC WD60 0UE-22HCT0 USB Device
CD-ROM/DVD : HL-DT-ST DVD-ROM GDR8164B (CD 48X Rd) (DVD 6X Rd)
CD-ROM/DVD : TSSTcorp CD/DVDW TS-H552D (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr)
Logical Storage Devices
Hard Disk (C:) : 228GB (220GB, 96% Free Space) (NTFS)
Hard Disk (D:) : 4.4GB (2.4GB, 54% Free Space) (FAT32)
CD-ROM/DVD (E:) : N/A
Colin's stuff (F:) : 4.1GB (CDFS)
Removable Drive (G:) : N/A
Removable Drive (H:) : N/A
Removable Drive (I:) : N/A
Removable Drive (J:) : N/A
Wd passport (K:) : 56GB (50GB, 89% Free Space) (FAT32)
Peripherals
Serial/Parallel Port(s) : 0 COM / 1 LPT
USB Controller/Hub : Standard OpenHCD USB Host Controller
USB Controller/Hub : Standard Enhanced PCI to USB Host Controller
USB Controller/Hub : USB Root Hub
USB Controller/Hub : Multimedia Card Reader
USB Controller/Hub : USB Mass Storage Device
FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : HID-compliant mouse
Human Interface : USB Human Interface Device
Communication Device(s)
Device : SoftV92 Data Fax Modem with SmartCP
Printers and Faxes
Model : Microsoft Office Document Image Writer
Power Management
AC Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2)
Network Services
Adapter : NETGEAR WG311v3 802.11g Wireless PCI Adapter
Performance Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
I've tried starting the computer in diagnostic mode, which works a little better but I get the same errors after a short amount of time. Any help would be GREATLY appreciated.
Old 03-10-2006, 12:47 PM
spkguitar's Avatar
Default Re: -9093 same old errors and I\'ve tried EVERYTHIN
Yes. (there is a reason why they recommend Firewire)
You have a few other potential issues there, too:
Disable that in the BIOS
disable those when using PT
These specs seem very familiar; did you change screen names?
That's built in video; disable it in the BIOS and try a dedicated video card.
Old 03-14-2006, 10:10 AM
Nope, same person...though I did notice someone in the forum does have a very similar configuration.
Thanks so much for the help. I went out and got another dedicated audio drive, this time a Western Digital 160 GB EIDE internal. Installed it, still the same problems.
I tried to disable
in the BIOS, but I could not locate them. I apologize, I'm a bit of an idiot when it comes to computers. Any help?
I disabled all of these in the device manager:
Any help would be greatly appreciated
Old 03-14-2006, 10:23 AM
casperfun casperfun is offline
Default Re: -9093 same old errors and I\'ve tried EVERYTHING
I had error hell at one time. If all else fails and you just want to record anything. This is what I did:
I ditched my usb/firewire external drive used it for archiving only.
Try this if your only truly desperate which I was.
Partition your internal system drive. With todays hard drive space you have plenty of room for your music. Start recording there. Yes against all tradional conventions but I was desperate. Now I can record more then 20 tracks and use a fair amount of plug-ins. Rewire reason adapted and ableton lite live. Most importantly I can make music with my set-up. That's all that matters to me.
Old 03-14-2006, 10:25 AM
spkguitar's Avatar
Well, as I mentioned to the other guy, to disable the onboard video, you're going to have to install a different video card (else, how would your monitor work? )
I'm not familiar with that machine, as I don't have one, but typically, there is a way to disable the modem (and other peripherals) from the main BIOS at startup.
Yeah, you and DUC user skipper have almost identical rigs and exactly the same problems: check the other thread for other suggestions.
Old 03-14-2006, 03:43 PM
I do not recommend partitioning your system drive. It will not give you any increase in performance. If you are going to record to the system drive, just do without the partition. Not sure if the WD firewire drive has the required Oxford911 chipset. I had troubles with both a WD 80gig and a WD 120 gig so I only use them for archive and transport to other studios. A second internal drive is a great solution that can be cheap if you hit the right sale. I just bought a Maxtor 300gig, 7200rpm, 16meg cache drive for $79 after rebates. That sale is over but that kind of deal pops up all the time between CompUSA, BestBuy and Circuit City.
Old 03-14-2006, 04:32 PM
Yes, I got an additional internal drive for all of my audio files...a 160 GB WD with 8 Meg cache 7200 RPM, but I still have the same problems. I'm going to go hit up the other thread now and retry all of the diagnostic stuff with the new hard drive, but geez! I ran the same LE Mbox system on an old tablet laptop about a year ago and didn't have all these problems...what a bummer.
If all else fails, I'll try the additional video card, but after shelling out all that money on the brand new computer and now the new hard drive, I'm a little wounded financially haha.
Any additional help is still appreciated!
Old 03-14-2006, 05:47 PM
Thanks for all the help friends, I finally got my rig working. I don't know what it was...I tweaked a few system performance options in windows and it got rid of my errors, though I'm sure it was the help that I received in this forum that did the trick. Thanks to everyone...time to go make music!
Old 03-14-2006, 06:42 PM
Ha! Looks as though I spoke too soon. Its back to its old tricks with a vengeance. I'm really stumped...
Old 03-15-2006, 02:11 PM
Greg B Greg B is offline
Have you checked the DMA settings of the hard drives? I'd think they should be at UDMA5. Repeated disk read errors can set some Windows registry values that set the buss speed very slow, and no longer offer the faster speeds to select through control panel.
One other thought is to see if your hard drives are sharing an IDE cable with your CDROMs. I believe that having a hard drive as master and a CD drive as slave slows the whole controller down to the CD drive speed.
002R Win7, no PT
GigaByte 970A-UD3/AMD FX(tm)-8120
8GB DIMM DDR3
AMD Radeon HD 6570
2 WDC WD10EURX-63FH1Y0
www.soundchasm.com
HW Buffer errors and Mass Confusion! 9093 Errors!! guitarlancer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-08-2007 10:38 AM
(-9129) and (-9093) errors no more! ANTDEM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-17-2006 11:11 PM
Errors 9093 and 9129 almendra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-30-2005 01:23 AM
still getting -9093 errors... EDurney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-28-2002 11:45 AM
still getting -9093 errors stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-09-2002 10:33 PM
