Can\'t Find Digidesign Hardware error?
I am running PT 6.4.1 (with a d/24 and a Mix farm and an Apogee 800) on a dual 1-gig G4 and I am in the process of installing OS 10.3.9 and all other software on an internal drive I recently reformatted. I have installed Pro Tools and Core Audio on this drive but when I boot PT tells me "Can't find Digidesgn hardware" and waits for me to turn it on... Except, the hardware IS on and there are no other connnection problems because if I boot to the other HD everything works fine.
Any ideas about what the problem might be? CS |
Re: Can\'t Find Digidesign Hardware error?
Hybrid configurations (yours) weren't tested. Neither was OS X v10.3.9 (though it works, so it may not be your problem). What is on your other HD that leads you to believe everything is fine?
im having similar problems. Im running a Mac Osx 10.4.1 with an M-Box, iv installed everything but upon opening the application it tells me that the hardware is in use somewhere else. Any ideas? i need to get back to beat making.
I have another drive in the same Mac that has everything installed and PT works fine with my hardware setup. Therefore, I know it's not the hardware.
hmm.. make sure no apps are holding core audio up. itunes, etc. check your audio utility and toggle different options.
I get the same error in osx but it works fine in os9. I have never been able to get this working in osx. would have been nice to of last night when i was switching between final cut pro in osx and pro tools in os9. |
I am using the last version of OSX before Tiger (10.3.9) and PT 6.4.1 on both drives. I am baffled! Also, when core audio is tied up it says so. This is a different error that just says it can't find the hardware.
Help! |
CStern - have you tried uninstalling and reinstalling Pro Tools, making sure to do a 'clean' uninstall?
I didn't think to do it because this was a newly formatted drive with a newly installed OS. Are you saying I should deinstall and reinstall anyway?
CS |
Can't find digidesign hardware, WinXP | wmorehouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-20-2012 09:09 AM |
ProTools 9 is still saying it cannot find any digidesign hardware. | playground_strifer | Tips & Tricks | 3 | 01-23-2011 06:29 AM |
Unable to find Digidesign Hardware | Mike De | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-16-2010 02:59 PM |
cant find digidesign hardware | krem2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-03-2009 11:47 PM |
Pro Tools can't find Digidesign hardware? | Doctor M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-23-2008 09:47 PM |
