Old 06-10-2016, 05:37 AM
amolin amolin is offline
Default Nudge clip gain don't work
The two top buttons at the wheel, is at default mapped to nudge clip gain up and down, but when I try to use them nothing happens.
The button don't even light up.
PT 12.4
Is this working for others?
Old 06-10-2016, 05:52 PM
creativecontrol's Avatar
Default Re: Nudge clip gain don't work
Works fine here. Did you modify the soft key set?
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-11-2016, 03:46 AM
I tried to modify it, just to test that the buttons actually worked...
Could it be because I'm on PT 12.4?
Old 06-11-2016, 10:17 AM
S6 2.1 is fully compatible with Pro Tools 12.4. The button doesn't need to light up as you are performing a momentary function. Just to be clear, this does not involve the jog wheel at all.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-13-2016, 06:59 AM
Ouch, my fault. I honestly thought I could press the button, and adjust gain with the wheel.
Thanks for clarifying that, and sorry for wasting your time...
Old 06-19-2016, 10:23 PM
lucienpalmer lucienpalmer is offline
I wish it worked like that! Been pushing that for a feature for a while.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 06-20-2016, 03:31 PM
It has been requested however it requires some work to be done in Pro Tools since it isn't currently a EUCONized function.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
Clip Gain nudge bugs and more cshaw macOS 1 02-08-2012 04:58 PM
