Could use a shortcut for soloing the track while in a playlist lane
When I go through takes in playlists view, I often want to switch back n forth between hearing them in the mix and hearing them solo. I feel there should be a [something]-S for toggling the track's solo button while the cursor is in a playlist lane. Is there a way to do this currently? If not, I'll add it to ideascale and propose option-S (on Mac), since that seems to do nothing right now.
Re: Could use a shortcut for soloing the track while in a playlist lane
Shift S does not work for you ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Shift S will solo the playlist, not the track.
Or the opposite
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Make sure Link Track and Edit selection are activated, select an edit selection on desired track in playlist view, use : and P buttons to move up and down selected playlist then use Shift+s to solo selected playlist... Voila!
The OP wants to be able to solo the playlist and then audition the take in context and soloed. Shift S only solos where the cursor is, so it's either the playlist or the track.
Clumsy workaround:
object-select the clip on the main playlist , shift-object-select the clip in an additional playlist : shift s will solo the playlist and the track (solo without context), move edit selection down, move edit selection up (now only main playlist is selected) : shift s will unsolo the track (solo with context).
on a related subject, I would really like a mode where moving up and down the playlists would have the solo follow the selection. So you wouldn't have to move the selection, then set the solo to follow (shift S).
If this was the case, shift S could be bound to solo just the track as OP is looking for. Anyone else wish for this? |
Hi All,
I'm behind this all the way. I'm on the verge of finally moving over from my trusty TDM HD3 systems, and I've been experimenting with Playlist comp'ing for a while now. I'm historically a "Mute Frees Assigned Voice" workflow kinda guy, which I have not been able to replicate with Playlists (apologies to all those who've seen me banging on about this elsewhere around here). If anyone would like to get a gist of what this "voice stealing" (manual voice assignment) workflow means, below is a thread discussing it (from Post #3) when HDX first came on the scene and it was realised that manual voice assignment had been removed. Paul V from Avid engineering came on the thread to say that they recognised that the voice stealing workflow is important to some people and that there were plans to emulate it. http://duc.avid.com/showthread.php?t=316448 My assumption was that Playlists would be where this would happen, so any improvements to the functionality of PL's is very welcome from my point of view. Regards. Steve Bush PS: JSComposer, I feel the same frustration as yourself over how the PL's solo (there's a lot that's a bit clumsy about PL's IMHO). Just so you didn't think I did a drive-by moan about Playlists in general, and hijacked your thread.
2 x Systems: MacPro 5.1 (Nehalem) 2 x 2.26 Quad Core, OSX 10.9.5 (Mavericks), PT10.3.10HD, 32 Gig RAM, PCIe HD3, 192's, Sync I/O, Midi I/O. |
Please.
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
Grouped Track Playlist solo shortcut??? | Epik Productions | Pro Tools TDM Systems (Mac) | 2 | 07-25-2010 09:51 AM |
LE 8.0.3cs2 not saving playlist lane filter settings?!! | cabbagerock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-06-2010 04:11 PM |
New Playlist shortcut? | Mix Master Factories | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-03-2010 03:32 AM |
New playlist shortcut? | jdutaillis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-20-2009 10:22 PM |
Shortcut for "New playlist" | FrauMitBart | Pro Tools TDM Systems (Mac) | 1 | 04-01-2005 12:57 AM |
