I'm a bit confused about the 192 I/O calibration. The manual says that the ouput is calibrated for -18dbFS ( output trim A ) and -20 dbFS ( out trim B ). Now i just read through the calibration thread and i want to calibrate my interface at -20 dbFS = 0 and 79 db SPL at mix position ( my mix room is tiny 10x11 and the recommanded 85 db is way too loud ).
When i send a pink noise to my 192 I/O ouput and i switch the ouput trim from A to B....how come i don't hear any difference. I mean shouldn't there be 2 db of difference in level ( loudness ) ?? Thanks. |
i found that the calibration for my 192 was WAY out of wack. so i used a multi-meter, connected the D-SUB to the analogue outs, selected the B trims, set a 1kHz tone for -20 (going out MONO channels), and adjusted the trims until each one read 1.228V (-20dBFS = 0 VU or +4 dBU, or 1.228v). then, i would go to the trouble of calibrating the A trims as well. THEN you will hear the difference.
you need a mult meter with enough resolution to read 1.228. hope that helps.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Based on this quote from the 192 manual:
------------ The 192 I/O is factory-calibrated so that its +4 dBu input operating level is set for 18 dB headroom above +4 dBu (maximum input/output +22 dBu). ------------ I was going to ask how do you guys calibrate -20dBFs to 0VU=+4dBU since the 192 only goes up to +22dBu absolute level. When calibrating -20dBFs at +4dBu you would always clip the 192 2dBs before full-scale is reached frank.
PTHDn 2020.9 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron |
Well theoretically you're right but practically speaking i don't think it's as simple because most analog devices ( Betacam Deck, 2"multitrack..) craps out at roughly 12 db above 0. Therefore if you know you will end up on Beta SP and if you were calibrated at - 20dbFS, your mix should not hit above - 8 dbFS ( 12 db headroom ) wich is still way below the absolute distortion point of the 192I/O.
I´m talking about mixing for film. the dolby-mod has 20dB of headroom above dobly-level.
A device made for playback on a film-stage shouldn´t distort 20dbs above 0VU=4dBu, if you ask me... If I´d mix for BetaSP day-in-day-out I wouldn´t calibrate to -20dBFs anyway. frank.
Most analog consoles will clip at +18dBu.. with older Neves clipping at about +22dBu.
The 192 manual states that the 192 will clip at +26 dBu (page 21) -- which gives you 2dB of headroom when calibrated at -20dBfs = +4dBu. At -18dBfs, you have 4dB of headroom. The maximum output of 22dBu simply means at full scale you'll be outputting +22dBu (your maximum value). The full quote: In +4 dBu operating mode, the 192 I/O is a 24-bit digital audio device capable of producing audio signals up to + 26 dBu across +4 dBu input/output. The default headroom value is 18 dB. This translates to a maximum output of +22 dBu. Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD •••••••••••••••••••••••••••• |
Frank,
Well, unfortunately i don't have the luxury of mixing for different media...usually the film mix will end up on DVD, Beta SP, Beta Digi.....Besides i think Rail got the right answer,the absolute level is + 26 dbFS and not + 22 dbFS so wether you're calibrated at 18 or 20, you're cool. |
Thanks Rail,
so I misunderstood the manual. It sounded like the maximum absolute level of the 192 is +22dBu. Frank.
888|24 Calibration question | jonnym | Pro Tools TDM Systems (Mac) | 0 | 01-17-2010 10:03 PM |
192 calibration question | robsubway | Pro Tools TDM Systems (Mac) | 0 | 09-12-2006 10:25 AM |
888/24 calibration question. | Allbaldo | Pro Tools TDM Systems (Mac) | 3 | 07-24-2006 12:09 PM |
another question about calibration !!! | vudoo | Post - Surround - Video | 15 | 03-02-2006 08:09 AM |
Calibration question.... | Vpr500S | Pro Tools TDM Systems (Mac) | 1 | 10-23-2002 11:08 AM |
