Old 12-20-2016, 08:56 PM
frankrmorrison frankrmorrison is offline
Default Opening older Pro Tools sessions in Pro Tools 12
I apologize, there are a number of threads related to this, but they all seem to have died and aren't quite hitting the salient points.
I am a former professional studio musician, songwriter, and touring musician, now hobbyist (and a professional software engineer in my post-music-industry life), and have used Pro Tools since 1998.
I have several sessions in Pro Tools 6.x format (PTS) and can do nothing with them now that i've upgraded my hardware, software, and replaced my ancient G5/Pro Tools 7 with a Mac Pro and Pro Tools 12.
Two comments:
1. it is absolutely ridiculous to remove save/session file compatibility from a software solution - what do they think will happen with all of the pro tools files down the line that need remastering/rerelease? At least in the old days, you could more reliably find a tape deck that could play back the reel-to-reel used for recording. These sessions are completely worthless if they weren't properly saved as a copy at the end of all work due to varying audio file start/stop times and lengths. Sadly, a lot of sessions i was involved in as a pro landed this way so audio files don't line up.
2. For the longtime pro tools users, we really need a conversion utility that will convert a pro tools 6-era file to something that can be opened by pro tools 12. Anyone know of any such solutions on the horizon? I'm striking out on the web.
Thank you, and I'm prepared to be flamed for restarting an old topic, but none of the others seemed to move towards a solution.
Old 12-20-2016, 08:58 PM
Default Re: Opening older Pro Tools sessions in Pro Tools 12
And yes, get off my lawn! :)
Old 12-21-2016, 07:17 AM
albee1952 albee1952 is online now
Hah. Old sessions will open fine, but I suspect your issue is that the old sessions have audio in SD II file format. I keep an old G4/Mbox in the closet for just this scenario. rumor has it that Logic can read and convert the SD II files, but I'm not sure how all that could work for you. I'm sure anyone with an old system(including me) would convert for a modest fee
Old 12-21-2016, 11:17 AM
The Weed's Avatar
The Weed The Weed is offline
Or, if you have it available and it's compatible with your current OS, install PT 10 as it will open sessions with SDII files.
Best practice would be to uninstall 12, install 10 then 12 or put 10 on a separate partition.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Pro Tools 11 Freezes When Opening Older Sessions saulls Pro Tools 11 4 05-04-2016 10:54 PM
Opening HD 7.4.2 Sessions on Older Versions Lumin Pro Tools TDM Systems (Mac) 2 10-30-2008 02:13 PM
Secrets to opening older sessions in PT 7 HD Chap Pro Tools TDM Systems (Mac) 8 07-29-2007 09:17 PM
PT7 crashing when opening older sessions mwingerski Pro Tools TDM Systems (Mac) 4 02-18-2006 03:54 AM
Crashing when opening up older sessions IO Composer Pro Tools TDM Systems (Mac) 3 02-25-2005 05:14 PM
