Old 08-02-2007, 04:31 PM
john1192 john1192 is offline
Default re-recorded tracks early by 34 samples ?
on a 002r with lynx aurora on the optical I/O clocking PT on the optical option ... buffer 128
i sent through my lynx aurora 16 out channel 8 analog and just returned it back into channel 8 analog and the re-recorded signal is 34 samples early on the timeline ...
if i do the same thing using the digi 002 analog ins and out's the re-recorded signal is 1 sample behind ..
anyone ever see this or can duplicate ... digi how could it be earlier ...
thanks all
john
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 08-02-2007, 05:07 PM
Default Re: re-recorded tracks early by 34 samples ?
update ...
when i record handclaps with one mic .. just me ... through the analog digi 002 in and the aurora 16 analog in's at the same time ... using tab v78m that has dual outputs ... the aurora 16 is 24 samples earlier on the timeline ...
cheers
RME BabyFace Pro
RME BabyFace Pro
Old 08-03-2007, 09:42 AM
bump .. anyone .. DIGI
RME BabyFace Pro
RME BabyFace Pro
Old 08-03-2007, 09:45 AM
mahler007 mahler007 is offline
I don't know how this happens, but I have experienced the exact same thing when re-recording out and back in through my Rosetta 200!
Andrew McKenna Lee
Composer/Guitarist
Digi 002, PT 7.1, Mac G4 Dual 450
http://www.andrewmckennalee.com
Old 08-04-2007, 04:26 PM
my guess is that the lynx and rosetta are that much faster but how could it be showing up before the playback track in the timeline ...
suspect ..
Digi ?
RME BabyFace Pro
RME BabyFace Pro
Old 08-05-2007, 09:06 AM
All converters have a conversion delay. ProTools corrects for the conversion delay in the built-in converters, but doesn't do it for converters on S/PDIF or optical.
If Digidesign wanted to get this right, they'd add an option for measuring and entering the appropriate adjustment number for whatever device you've got connected.
Quad 2.5 G5, 4.5G RAM
Old 08-05-2007, 12:50 PM
so it ia all or not at all
in other words ... either use the digi converters or the outboard hanging on the optical ports .. but not both at the same time ..
or move regions to match once all is recorded ...
i did red once some advise about using t different sets of converters ... do not hang a stereo pair across the different converters as the timing will be off ...
i am coming from an HD rig and did not get a chance to test with 192 I/O but the ADC works great with the Lynx ... that sems to tell me that th converter speeds must be similar ... but the 002R is slower for sure ..
anyone else have any thoughts opn this ... has anyone recorded with both sets of converters (i am sure there are alot of you) and noticed anything odd with this happening timing wise ?
thank you
john
RME BabyFace Pro
RME BabyFace Pro
Old 08-07-2007, 11:06 AM
bump ...
RME BabyFace Pro
RME BabyFace Pro
Old 08-09-2007, 10:14 AM
bump for Digi
RME BabyFace Pro
RME BabyFace Pro
Old 08-09-2007, 10:34 AM
DigiTechSupt's Avatar
I'm going to test this, but I want to be sure I'm routing things properly.
You're going out optical ADAT to the Lynx, then analog out of the Lynx to an analog in on the Lynx, correct? Does the track you're routing out have any plug-ins on it? What sample rate are you using?
Avid Audio Tech Support
Support FAQ
Recorded audio placed 40ms too early peteage FireWire and USB Audio Interfaces (Win) 3 09-11-2013 08:05 PM
Midi recorded early allstaar macOS 2 05-09-2011 03:27 PM
Recorded Tracks are .040 seconds early kevinb511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-16-2007 08:28 AM
Click plug in is early when recorded stormpro Pro Tools TDM Systems (Mac) 5 08-13-2006 10:23 AM
recorded tracks delayed by about 3k samples?!? theguru 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2006 01:27 PM
