Old 03-04-2005, 01:27 AM
Colors Colors is offline
Default Constant High Pitch Whine from Windows MBOX Setup
OK
1a. I hear a constant high pitch whine with my m-box connected to my windows machine.
1b. I have my self powered monitors switched on but with the volume set to 0 and I still get this high pitched whine.
2. It only happens when I open Pro Tools. When I shut it down, the annoying whine goes away but there is still a soft and low electronic 'gurgling'.
3a. When I use my delta audiophile 2496, I don't get any strange sounds such as the ones described in numbers one or two. With this rig the output is crystal clear. I haven't changed the monitoring setup except for an AB cabling comparison which yielded the same results.
3b. (All IRQ's are independent)
4. On the other hand the m-box does have a clean signal from the headphone jack.
5. The high pitched sound is more reminiscent of a data stream than it is of a ground hum, buzz or other similar current related issues.
Colors,
6. It is very annoying when you work for hours while living with this sound.
7. Help. What are some possibilities? My suspicion is the USB interface is causing the interference. Is this a common occurance?
8. Probably just a hidden little knob that got accidentally switched on, right?
Colors
3 ghz P4
ASUS P4C800 Deluxe mobo
3gb PC3200 RAM
SATA RAID 0 160gb
Mbox
Delta Audiophile 2492
PT 6.4
Win XP SP2
KRK V6's
Old 03-04-2005, 02:08 AM
Slim Shady Slim Shady is offline
Default Re: Constant High Pitch Whine from Windows MBOX Setup
Try posting in the windows forum, this is the Macintosh forum.
Old 03-04-2005, 02:32 AM
TCDet TCDet is offline
On Mac's (Mirror Door) I have six whiners (Mbox) Balanced, non balanced Mondo USB cables.....
It seems to be the RF environment more than the Mbox itself.
Any Mbox I bring into this lab has the hi-pitched whine.
Sweetwater and Digi reps came by and never had heard of this before(!?!?)
Still annoying as ever.
Maybe some mu-metal to build a shielded box for the Mbox.
Old 04-01-2005, 08:51 AM
megahurt megahurt is offline
I have all this going on with my MBox and PowerBook. I hate it. Any solutions?
Old 04-23-2005, 12:33 PM
I hooked it up to my mac with the same results. I swapped out the USB cable with no difference. It's a horrible sound. VERRYY distracting.
Old 04-26-2005, 10:46 AM
No new developments except this. I took my friends M-box which makes no noise on his system and hooked it up to my system and there it was. The digi high pitch whine of doom! I should never have traded down from my digi 001.
I can't imagine what the problem is. I have swapped out all the relevent cabling and have tried numerous configurations but the sound remains.
Could the usb interface pick up interference from an unclean power source perhaps? This is driving me nuts. PLEASE DIGI WON KENOBI your my only hope. Aren't there any digi guys trolling this forum who can ofer a pearl or two of wisdom?
Old 04-27-2005, 09:39 AM
It blows my mind that a Digi guy won't answer this... it is SUCH an annoying problem.
I am convinced it has something to do with FireWire, but of course Digi will not cofirm or deny. Who the heII are we supposed to ask?
Mbox 2 high pitch whine Doner005 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-14-2009 08:55 AM
High Pitch Whine SOLVED cal1875 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-05-2008 08:58 AM
High Pitch Whine MacBook Pro/Mbox crash4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-23-2007 06:30 AM
High pitch whine/buzz djrobbie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-30-2005 08:54 AM
High pitch whine or noise when recording Isabelle Pro Tools TDM Systems (Mac) 12 02-06-2004 05:41 AM
