Old 04-29-2020, 03:13 PM
snowplaysmusic snowplaysmusic is offline
Default Volume Fader versus Clip Game
Hi, I am tracking an electric bass. It's quite hot, which I like. Peaking around -5dbFS. To give myself more headroom during mixing, I need to drop the track by about 10dBFS.I don't want to do it on the source side, because I like driving the tube amp. On Pro Tools side, I thought I clip gain. Seems like a great solution. But then I noticed the Volume fader on the mix window. I have to admit, I don't know precisely how it works. What would be the difference from removing 10dbFS with clip gain versus dropping the volume fader on the mix window?
Old 04-30-2020, 04:10 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Default Re: Volume Fader versus Clip Game
You can use a Trim plug-in on the track to lower its' level.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 451.48- Internal WD Black, Samsung 860, and MSATA card - Davinci Resolve 16.2.3.015 - Canon HF G40
Old 04-30-2020, 06:33 AM
Sardi Sardi is online now
Clip gain is pre insert. Fader volume/level is post insert.
Also, driving your tube amp for colour is fine, but you don’t need to run it into your interface hot. Back off the input gain, record at 24bit and give yourself a bit of headroom.
Old 04-30-2020, 12:16 PM
Ben Jenssen's Avatar
Don't overthink it.
If you like the sound, whether it's the source (the bass) plugged directly (DI) into your interface, or your bass amp with a microphone in front of it, just see to it that it's not clipping, and record it. If you're talking about a bass amp plugin insert on the track, then know that it's effect is not recorded and you can change it later.
Like my friends stated, there are more ways than one to adjust the level when the track is recorded; Clip Gain, Trim insert, and track volume fader. The fader the most important because it adjusts the volume after inserts, like on a analog mixing desk.
So: record tracks without going into the red, and adjust the track faders so it sounds like a mix. Pan and maybe effects. Simple.
Old 05-01-2020, 07:31 PM
Thank you. Yes, I like the color tube. I do record at 24bit. How do I back off the input gain? My pre-amp has a gain (color tube) stage and an output level stage (clean/trim). You mean dial back the trim all the way?
Has Clip List audition volume always been tied to Audiosuite audition volume? leftalive Windows 3 06-15-2019 04:50 AM
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
volume fader in custom fader mode KimSira ICON & C|24 4 10-15-2008 09:54 PM
Track fader volume to send volume smmdrum Tips & Tricks 9 08-12-2008 05:22 PM
