Old 09-04-2000, 06:35 AM
sandman sandman is offline
Default HELP ! locking VST >>PT via iac
well , my pc lap top has crashed with all my sequences of cubase..
much truble here... (harddisk dead as...dead )
so i have now VST 4.1 on mac and i try to lock it to PROTOOLS via
iac driver
its working but not quite smooth
any tips ? CAN it work 100% accuracy
anyone tryed that /doing this ??
how many ram should i give to PT /cubase
i'm looking for trouble , am i ?
G4 450mhz
256 ram
20g
thanks for any help .
Oh, it gives off an orange cloud of light, that just flows right out over the sea... wow!
Old 09-05-2000, 04:32 AM
Default Re: HELP ! locking VST >>PT via iac
DIGIsupprt NEED a support here
on the manual one exsample goes to diferent PGM
a not the popular one ...
thank you
Old 09-05-2000, 09:30 AM
Kevan Staples Kevan Staples is offline
The instructions in the Protools manual describe how to do it with Vision. The same applies to Cubase.
1 You must set up two IAC busses in OMS. One should be MTC bus and one should be MMC bus.
2 In OMS set "Run in Background" as your pref.
3 In Cubase choose Midi Setup and enable the MTC bus but disable the MMC bus.
4 In SYNC options choose MMC bus as Timecode base and MMC bus as MMC Output. Place Cubase in "Play in Backround" and put it in SYNC mode.
5 In Protools..Open the "Peripherals" window from the "Setup" menu. Use the first available Midi Controllers popup to select MMC and select the Receive From to your MMC bus.
6 Choose the "Show Session Setup Window" from the "Display" menu and check "MTC To Port". Select the MTC bus to send the Midi TimeCode. Select the appropriate frame rate.
7 Place ProTools in "Active in Background" mode from the "Options" menu.
You should be able to operate the transport from either application and have the other application follow transport commands. Remember that both applications cannot access the same piece of Hardware so you must disable audio in Cubase or use Sound Manager or another audio card if you have one.
Let me know by private email if this helps..if not I could send you some files with picts to help you out.
Kevan
10.3.6 Locking up jimst57 Windows 7 07-07-2013 05:50 AM
Question: Auto-locking and Mute locking Charles Deenen Pro Tools TDM Systems (Mac) 1 09-25-2010 01:07 PM
Locking up via LTC nobby Pro Tools TDM Systems (Mac) 4 11-10-2009 12:00 PM
HD LOCKING UP!!! s0nguy Pro Tools TDM Systems (Win) 5 07-27-2004 07:12 PM
PT LE 501 locking up bvleugels 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-03-2002 06:27 PM
