Old 10-21-2004, 05:36 AM
daboosh daboosh is offline
Default Locking 2 001\'s together?
Is there a way to lock 2 001's together with one as the master and one as the slave for 64 tracks?
(Using 2 macs)
Da BOOSH Studios
http://www.DaBOOSH.net
Old 10-21-2004, 09:18 AM
ariel keshet ariel keshet is offline
Default Re: Locking 2 001\'s together?
why not
you would need a midi time piece or ant other midi clock interface . just connect your master mac to the in port on the interface - then connect your slave mac to the out set the clock of the slave to external and that should theoreticlly do the job
G5 1.8ghz 10.3.8 768ram
Protools6.9 waves V.5
Mbox(waiting for 002R)
neumann tlm103
Tlaudio 5051 v.2
genelec 1030
yamaha p-90
Old 10-21-2004, 10:36 AM
You don't need any extra hardware, it can be done with the 001 MIDI ports. You can use S/PDIF or Lightpipe to sync the converters, and MIDI to sync the transports.
Quad 2.5 G5, 4.5G RAM
Old 10-21-2004, 03:09 PM
Notefarm Notefarm is offline
The above advice is sound,
I do it all the time, an 001 on a G4 and 002r on a DP G5, I use ethernet to drag files from one to the other. So i have the Macs on a network. I am glad I kept my trusty 001 system.
It works well and has so far worked flawlessly.
What games shall we play today?
http://www.notefarm.net/
Old 10-21-2004, 04:32 PM
Icabod Icabod is offline
Are you running the same version of the OS on each machine?
How about PT, same version on each?
If so, which versions?
I have a G4 400 on which I don't really want to run X (too slow), and a G4 1Ghz laptop that I am running Panther and PTLE 6.4.
I don't have a need that many tracks or inputs, but it would be fun!!
12" PB 1Ghz, 512 RAM, Panther
002R PTLE 7.1
60 Gig Maxtor 7200, Oxford 911 FW/USB2 box
Old 10-21-2004, 04:46 PM
I run 0s 9.2 with the 32trk BETA on the G4 and 0S X (10.3.4) on the G5 Runing PT 6.4.
My G4 was left just as I used for Pro Tools when it was my only PT set up.
Peace and Good Mixes To All
NoteFarm
Old 10-22-2004, 07:40 AM
Thanks Notefarm,
I have to try this when I get a chance. Sounds like fun!!!
Are you running a midi cable between them to sync them, or are you using S/PDIF?
002R PTLE 7.1
Question: Auto-locking and Mute locking Charles Deenen Pro Tools TDM Systems (Mac) 1 09-25-2010 01:07 PM
2 001's in 1 pc? Ruba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-09-2004 06:27 AM
Can I use two 001's simultaneously? Moot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-14-2001 05:36 PM
Two 001's in the same PC? Hannon Lane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-02-2001 09:48 PM
syncing 2 001's mattfell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-26-2001 01:19 AM
