Plugin disabling in multi user setup
I doubt there is, and I tried a few things and searched this forum and the interwebs, but I was wondering the following:
Can you setup an OSX multi user system were certain plugins are only available/visible in certain users? So if I install a bunch of plugins in my user that would be on my iLok for instance, they're not seen in someone else's user so they don't get messages that the authorization is not available or asked if they want to move the plugins to the unused folder. Would be a handy feature if it can't. |
Re: Plugin disabling in multi user setup
Since plugin folders are located in the system library folder, not user library folder, I don't think there is a way to automate this.
Here's what I would do: On each user, create an alias of the Plugins folder and the Unused plugins folder and put them on the desktop. Color code the aax files according to who is going to use them, and instruct the users to manually move the files from one folder to the other before they launch PT. Should be workable, and not too much hassle. Set the folders to sort by color. IHTH. Edit: Of course, you could create applescripts to automate this moving of aax files, but that's another cup of tea.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Create alias folders in the System plugins folder for each user that links to the actual folder located in each user's document folder. Drag the AAX plugins that belong to each user, to their alias'ed folder while logged in as each user.
Pro Tools should not be able to follow down the alias (sym-link) folder to a folder located in a private user account so will dead-end when scanning for plugins on those folders if not logged in as that user. You just need to make sure you do this in the right order (or know how to change permissions on folders) so you don't create system accessible folders but create user owned folders in each user's document folder. Create the folder first in the user account/Documents and then place the alias in the System Plugins folder (will have to do this for each user as logged in as each user). You can also have duplicates (say two people have the MDW EQ plugin, you can copy the AAX to both user's plugin folders)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Pro tools 9 with multi i/o multi OS setup | lozkane | Pro Tools 9 | 0 | 01-02-2011 03:51 PM |
multi-user on mac | alance | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-07-2004 05:07 PM |
Multi-user environment for PT6 | msawitzke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-16-2004 07:05 PM |
Multi user/extension sets in OS X... | leftalive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-11-2003 12:35 AM |
disabling a plugin temoporarily without losing settings | el matador | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-23-2001 12:53 AM |
