#21
Re: Pro Tools 5.1 export channel order
For anyone still being annoyed by this, there's a free solution now: MChannelMatrix by Melda Production. Easily swap your layout around until it matches the CAF channel-order (SMPTE).
#22
However, when you export an interleaved 5.1 WAV, it has the channel ident flags, but not all software can read them properly. Windows media player and Nero can, QuickTime and Premiere Pro do not, resulting in channels being laid and played out in the wrong order. QuickTime expects the layout to be LRCLfLsRs. So if it does a tail end fold down to stereo, the placement will be wrong on that as well.
Pro Tools Utimate 2018.7, on - i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB; Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB; "Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB. RME FireFace802 + ARC, RME Babyface Avid D-Command, Artist Control, V-Control, Korg MicroKontrol 7.1.2 Presonus Monitors |
#23
Does anyone know of a utility that will rearrange the order of the tracks of an already exported file, in case we need to deliver files in the Film format, or the DTS format?
#24
I believe Wave Agent does this...!?
#25
That's what I was hoping since it is free, but I couldn't figure out how to do it without spitting out a bunch of mono files, renaming, and then importing again. Is there a way to go from poly file to poly file with the tracks re arranged? |
#26
I created a plug-in that will
I created a simple plug-in that converts "Film" to Smpte layout. Easy to bounce. Let me know if it helps http://www.cocellproductions.com/Fiss/Fiss.php |
#27
I wonder about that it seems to be different in my setup: Using PT HD10.3.10 on OSX. Routing in PT is straight forward and default ("Film"), meaning L-C-R-Ls-Rs-LFE. When I bounce to a interleaved WAV, and then open this 5.1 WAV with every multichannel tool I have, it opens it in the ITU/SMPTE channel order of L-R-C-LFE-Ls-Rs (FCP7, Cubase6, SoundStudio4, DolbyMediaDecoder). With this I assume that PT bounces interlaved 5.1 WAV actually in the ITU order, although PT internal and physical output is in "Film" order.
(It's different when I bounce to a interleaved AIF: When doing so, the channel order is actually PT/Film style.) Did I overlook something? |
#28
CAF channel-order still wrong in 9.0.5 | Arno Peeters | Post - Surround - Video | 3 | 07-26-2015 07:55 AM |
Locked Channel order in Bus | bcslaam | Pro Tools 11 | 3 | 08-29-2013 12:11 PM |
Can you change the default channel order of an interleaved.. | dj_grimmace | Post - Surround - Video | 4 | 11-12-2007 08:10 AM |
Import and Export Interleave Files in SMPTE order | erikf | Post - Surround - Video | 14 | 08-19-2007 11:30 AM |
Changing channel order in bounced files. | JonHallur | Pro Tools TDM Systems (Win) | 4 | 04-04-2007 12:57 AM |
