Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 12-03-2020, 03:34 AM
jchan jchan is offline
Default Import AAF crashing PT 2020.11
Anyone successfully imported an AAF in 2020.11?
For me it crashes every time.
High Sierra.
Old 12-03-2020, 06:44 AM
peapodpost peapodpost is offline
Default Re: Import AAF crashing PT 2020.11
many so far without issue... where is your AAF coming from?
Old 12-03-2020, 07:41 AM
Davinci Resolve. Not sure what version.
1 video track.
12 audio tracks.
Seems to be the videotrack that's crashing it. Works if video is not imported.
Hm.
Old 12-03-2020, 04:37 PM
smurfyou smurfyou is offline
Video track import is unreliable (and unsupported) coming from Premiere or Resolve. It only works properly from Avid MC in my experience.
~Will
Old 12-04-2020, 12:33 AM
Thanks for sharing experience. Always good to know before you start banging head to the wall :)
I'll probably just import audio and import the video separately.
By the way:
Since I'm not that experienced working with movies, HOW would you go ahead in this case.
I mixed and delivered a short commercial.
Then they wanted to cut out some scenes, making the whole ad maybe 10 seconds shorter.
How would you go ahead doing that? With the least amount of redoing your work from scratch.
Old 12-04-2020, 04:43 PM
Assuming you don't get notes about what was cut...
Save a copy (obviously!) and import the new video and guide track. Play your mix and the new video and guide track together until it doesn't match. There is your first change. See if you can match the edit they made using your tracks. Repeat.
If it really is just stuff cut out those are the easiest changes. When they start changing edits and adding material it gets more complex...
~Will
Old 12-04-2020, 05:01 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
No problems here importing aaf files into Pro Tools v2020.11
It works fine regardless of what procedure I'm using
  • Double-click the AAF file
  • Using the Import Session Data Dialog
  • Opening from the Workspa
ce Browser
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
protools 2020 Windows 10 fresh install - Crashing with graphic glitching PDestruction Windows 13 10-19-2023 05:06 PM
Pro tools 2020.11 crashing and will not open G374 Pro Tools 2020 3 11-06-2022 06:26 PM
Amplitube 4 crashing PT 2020.5 Windows? mkosacek AAX Plug-ins 3 09-04-2020 03:34 PM
protools 2020.03 AVID broke OMF import basharar1 Post - Surround - Video 34 05-21-2020 01:33 PM
2020.3 Import Session Data buggy RichR Pro Tools 2020 4 04-23-2020 03:55 PM
