#41
Re: Subscription for Carbon driver?
#1 If by class-compliant you mean a driver is not required, then yes it's class compliant on Mac. #2 Totally understand on your concern with firmware updates. I can't predict the future, but my philosophy is that firmware updates should be freely downloadable and installable outside of Pro Tools in the future. #3 Preamp settings are always available via front panel. We don't currently have any kind of software control of preamps, but it's high on the priority list. In Pro Tools, Hardware Setup is currently the only way to change the monitor sets enabled (Main/Alt 1/Alt 2), headphone sources, dim level, and talkback gain. This may change in the future, but that's how it's done now. #4 You cannot have DSP and Native plugins active simultaneously on a track. This is because DSP Mode automatically inactivates Native-only plugins (which VIs always are) in order to preserve low latency. What you can do it route the output of an Instrument track (with VI) to a track in DSP Mode. However, there is no monitoring latency benefit to doing that. That clear things up?
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
#42
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
#43
#44
Actually I almost always use my Bricasti M7 hardware unit as my reverb for everything. So I am assuming that it being a "hardware insert" on it's own Aux track and being an I/O selection of the inserts section , it would not need to put in DSP safe. Honestly the one thing I wish was included on the Carbon that my Omni had was an AES in and out.... Given that the Bricasti it only has AES as the digital connections . So now I will have to use the analog I/O's on the Bricasti which is OK,,, but I liked the Idea of staying digital, and not having to do another round of A/D and D/A conversion
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... Last edited by K Roche; 12-06-2020 at 09:56 AM. |
#45
https://lukehoward.com/ |
#46
Thanks,,, but ya that's a bit pricey, lots of people just run the Bricasti in analog and seem to do fine. And given it is a Reverb unit even if there is some small extra latency because of going through the conversion, as noted it really just comes across as a bit of pre delay so not $1k worth of issue
#47
It is a pity that AES/EBU I/O was left off both the MTRX Studio and Carbon though! One day everything will be connected with Ethernet, there will be one true audio protocol, etc etc.
#48
But what I have found that even with with my analog outboard Comp, that because it already shows an amount of compensation on it's Aux track I assume from (ADC) being activated , without entering anything on "HW Insert" I assume it's being handled ?
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... Last edited by K Roche; 12-07-2020 at 06:26 AM. |
#49
If Carbon could support optical S/PDIF, would something like this resolve your issue with connecting the M7 via AES?
#50
Honestly connecting the Bricasti via analog is not a big issue for me and I will do so on the Analog DB 25 , Which will still leave the 8 mic/line inputs free. I actually only have 3 HW units .... #1 A-Designs MP2A two channel mic pre (which I will run it's Out's into the (Input ) DB 25) #2 IGS TubeCore 3U two channel Compressor ...... In's and Out's to the DB25 's #3 Bricasti Two channel ....In's and Out's to the DB25's I am not commercial, and only record myself, and so the Max number of mic's I might use at one time are 3 ,,,,,,so I see the Carbon as being perfect for my minimal self recording artist type needs. I suppose that Hosa adaptor box would work ( but I am not an electrical engineer), Also thought the Carbon does not have a S/PDIF optical ports anyway, So I don't understand ? Or are you just asking for future reference ? One more quick question, I think I remember on one of the numerous video reviews something about the input jacks being "smart connections " and was given to understand anything plugged into either the 2 front panel jacks or the 8 combi XLR's on the back, will automatically override any DB 25 connection's, correct ?" So once set up in the I/O matrix I don't have to change anything other than plugging or unplugging the jacks as needed ?
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... Last edited by K Roche; 12-07-2020 at 02:07 PM. |
Pro Tools 12.5 Student Subscription - HD Driver Installer? | Adrian Wall | Pro Tools 12 | 6 | 04-28-2016 11:54 AM |
Cocoa or Carbon? | Drew Mazurek | Pro Tools TDM Systems (Mac) | 7 | 02-17-2003 09:45 AM |
OS X Carbon error | Armando | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-26-2001 03:53 AM |
