Seperate Feed to headphones?
Is it possible to just send a signal to only the headphone output on the omni?
Re: Seperate Feed to headphones?
Yes. That's what the CUE button is for, next to the monitor control. In Protools you will see the option for outputs 9-10, which is the CUE output. You can create sends that go to output 9-10. Whenever the CUE button is pressed (and lit), then that means the headphone jack is receiving output 9-10. When the CUE button is not pressed, then the headphones are mirroring the main monitor output.
Problems with recording mic feed | themanontv | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-26-2011 11:01 AM |
RSS Feed??? | i hear dead people | Pro Tools TDM Systems (Mac) | 0 | 06-22-2007 06:33 AM |
Feed Back | March314 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-20-2007 08:34 PM |
LFE feed level to Lt/Rt | CCash | Post - Surround - Video | 3 | 08-08-2003 08:10 PM |
Using Direct Pro Q10s Mic Pre to feed 001? | Sushi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-15-2003 03:00 PM |
