Old 03-28-2013, 03:38 PM
Loudyman's Avatar
Loudyman Loudyman is offline
Default Some questions related to AUX tracks, ADC and recording.
I have a doubt concerning the behaviour of ADC with AUX tracks ;
On a TDM system, with global ADC on:
1) Let's say I have several audio tracks (drums) routed to an AUX track, to create a drums bus.
If I put plugins on that AUX track, will it be compensated by ADC ?
Sorry if it's obvious, but sometimes ADC confuses me!
2) I know that using RTAS plugins on AUX tracks eats up voices, but are there any other downsides ?
I remember a thread where it was recommended to use RTAS in inserts and TDM in sends, but I don't remember all the reasons.
3) What is the usual way to record a track with an effect without printing it ?
For example, I want to record a voice without any effects, but the singer needs to hear a reverb (plugin) while recording;
How would you do the chaining in Protools ?
I didn't find the answers in the manual.....
Your help is welcome !
Thanks,
Ludo.
Mac Pro 8 cores Intel Xeon harpertown 3Ghz (Early 2008)| ATI radeon HD 2600 XT | 16GB RAM | 750GB system drive + 3x1TB drives |
MAC OSX 10.6.8 | Protools HD 10.3.2 |
HD3 PCIe Accel |
192 I/O |
Old 03-28-2013, 04:41 PM
Craig F Craig F is offline
Default Re: Some questions related to AUX tracks, ADC and recording.
1)
mixes yes, ADC compensates correctly
tracking no, I find ADC is off
2) potently exceeding ADCs limits if the H/W Buffer is to high
3) the same way I would on a Neve or SSL,
a send from the vocal track to an Aux with a verb plug on it
Thank you,
Craig
Old 03-28-2013, 05:25 PM
Loudyman's Avatar
Thank you Craig,
1) Is it normal behaviour for tracking ?
I thought we had to desactivate them manually ?
I've read that ADC on tracks worked this way :
Audio Tracks REC armed = ADC Off
Audio Tracks REC off = ADC On
AUX Tracks = ADC Always On / Manually switch Off
Master Fader = No ADC
Isn't that correct ?
HD3 PCIe Accel |
192 I/O |
Old 03-28-2013, 05:29 PM
I thought you were talking:
Input > Aux Track > Audio Track
Thank you,
Craig
Old 03-28-2013, 06:03 PM
Loudyman's Avatar
No problem !
However, is it the way ADC works ? :
3) So, if I understand well, in this case: Vocal track send > Aux with a verb
While recording, the ADC on the vocal audio track will be OFF, but the ADC on the Aux track will be ON ?
If I use a RTAS reverb on this Aux, the delay will be = RTAS plug delay + buffer delay
If I use a TDM reverb on this Aux, the delay will be = TDM plug delay
No matter if ADC is ON or OFF on the Aux track, these delays will be there, right ?
HD3 PCIe Accel |
192 I/O |
Old 03-28-2013, 06:06 PM
H/W buffer delay x 2 (one to get out and one to get back in)
I don't know, I don't track with ADC active
Thank you,
Craig
Old 03-28-2013, 06:08 PM
WernerF WernerF is offline
Why not?
Old 03-28-2013, 06:51 PM
Loudyman's Avatar
OK,
To reword my first question,
I have recorded everything, and I have a classic mix with drums, guitars, vocal etc...
If I want to make a subgroup for my drums for example, so I can put a nice bus comp plugin on it ;
A) what kind of track should I use and how to route everything ? (send or direct output........Audio or Aux tracks ?)
B) If it's an Aux track, does the ADC will compensate for the nice bus comp plugin on that Aux track ?
Again, I think it's a noob question, but when one doubt !
HD3 PCIe Accel |
192 I/O |
Old 03-28-2013, 06:53 PM
a) Aux
b) yes
Thank you,
Craig
Old 03-28-2013, 06:58 PM
Originally Posted by WernerF View Post
Why not?
a) ADC eats DSP chips
b) I don't do complicated bussing or use plug-ins when I track (aside from some reverb on Aux tracks but I shave a little off of the pre-delay for that)
when we go HDX I may reconsider
Thank you,
Craig
Two SYNC-related questions RinnyTin Pro Tools TDM Systems (Mac) 11 09-27-2004 08:38 AM
2 Questions I-Mac G4 M-Box related DrewEpton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-24-2003 04:48 AM
a few related questions Kosherbeets 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-29-2003 01:49 PM
Radio related questions Engramic General Discussion 1 01-24-2003 06:39 PM
2 Questions...5.3.1 related Captain_Pants 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-20-2002 08:24 PM
