Plug ins not showing up as inserts
I'm installing a new protools system for a friend: specs: 2x2.66 GHz Dual-Core Intel Xeon G5 (2G RAM), OSX 10.4.8 MBOX2, Pro Tools 7.1.1cs2 I'm trying to install Garritan Personal Orchestra and the IK Multimedia stuff that comes with PT. They all seem to install properly (I.e. the RTAS files show up in the Plugin folder within the digidesign folder, as well as in the application support/digidesign/plugins list. When protools loads though, they are not available in the insert/audiosuite. I've trashed prefs and databases, checked the compatability both on this site and the ik & gpo sites and can't find any answers. I've reinstalled all software fresh to no avail. Any ideas?? Thanks
Prism Orpheus, PT 11, Mac 2x2.26GHz QuadCore Intel Xeon, 16g ram Outboard - ADesign, Chandler, RetroDesign, Roland. |
Re: Plug ins not showing up as inserts
Did you download the Intel (aka Universal Binary) versions of the plug-ins? You'll have to get the Garriton installer from their site, but anything that was part of the Ignition pack can be found here: http://www.digidesign.com/index.cfm?...&categoryid=36
thanks for that, I'll tell him to give that a go!
Are any of the other plug ins showing as inserts?
I had this problem when I first installed pro tools. I eventually figured out through trial and error an easy fix. Go to library/application support/digidesign/plugins get info on the "plugins" folder check the read write permissions. In my case for some reason I did not have full read/write authorization. Rectifying this sorted my problems. hope this helps
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4 |
Inserts not showing up | RoxyRiot | macOS | 1 | 09-13-2013 06:58 AM |
Inserts Not Showing FL Plugin | jace314 | Pro Tools M-Powered (Win) | 1 | 09-13-2010 11:08 AM |
Plug-ins not showing in Inserts | Revolver73 | Virtual Instruments | 2 | 10-09-2007 10:34 AM |
pro tools ignition pack plug ins not showing up in inserts | yanncrusoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-06-2007 12:10 PM |
Mbox2 Plug-ins aren't showing up in my inserts | BroganSound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-25-2007 09:52 AM |
