#21
Re: Anyone using Blackmagic Decklink mini monitor?
Connect your studio's coax line (the one that you were going to use for composite video) to the card's SDI output. In the studio, use an SDI-to-HDMI converter. If you have a spare cat5e in the walls you could use HDMI to cat5 converters (a.k.a "balun")
#22
You could use SDI over your existing tie lines, and have a SDI to HDMI converter in the Foley room. SDI was designed for this purpose - to be able to run digits over existing infrastructure.
Pro Tools Utimate 2018.7, on - i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB; Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB; "Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB. RME FireFace802 + ARC, RME Babyface Avid D-Command, Artist Control, V-Control, Korg MicroKontrol 7.1.2 Presonus Monitors |
#23
use the sdi signal and buy 30€ sdi to hdmi converrters. much cheaper than using long hdmi cables and you can use very long runs with sdi without having to buy these crazy expensive cat 6 or fibre extenders
f.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 10-25-2015 at 11:29 AM. |
#24
Great. I've ordered converter and will get back to you when I have a chance to get everything running.
Thank you. |
#25
For long runs you'll need SDI co-ax cables. But they cost way less than HDMI cables. f.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#26
#27
Hey Guys,
So I tested HDMI out and through converter box and I get Video. Thank you all. But now, no mater what config I use on the desktop video sys pref or video import into protools I get this small picture. I've tried both 720, and 1080 videos. I can't seem to get it to fill the screen. I've also reached out to Blackmagic and waiting to hear back. |
#28
That could be a setting on the TV. Not sure. Never seen that. I use a Decklink SDI with 1080P 24fps/25 and 23.98 DNxHD36 codecs depending on the project with any output-conversion settings set to OFF in the BM prefs.
What kind of conversion box is that? SDI to HDMI?
#29
Hey Frank, this is straight off the HDMI. I've tried all those codecs as well as DNxHD36, and every setting on my TV. same result. Also played around with the settings on my Video Desktop v. 10.5. It's been mention I should go back to video desktop 10.3.7. Maybe I'll try that. As I mentioned, I'm also waiting to hear back from Blackmagic.
thanks |
#30
Ok so I did a test with Blackmagic's software Media Express and got video FULL screen. But coming out of protools I get mini screen. ???
Running PT 12, Mac Pro Yosemite, desktop video v 10.5 Will try a test with v 10.3.7 soon as I can. Frank what version of Pro tools and Desktop video are you running? Last edited by angelo panetta; 10-30-2015 at 08:57 AM. |
AJA T-Tap vs Blackmagic Mini Monitor test | MIKEROPHONICS | Post - Surround - Video | 58 | 11-01-2015 11:03 AM |
HD 10.3.10 PCI Overflow with Blackmagic Decklink Mini Monitor | rantanplan | Pro Tools TDM Systems (Mac) | 12 | 08-16-2015 01:55 AM |
PT 10 & Blackmagic UltraStudio Mini Monitor | Fedenev | Post - Surround - Video | 10 | 08-02-2014 10:34 PM |
Have anyone use the BlackMagic Decklink Mini Monitor | M-ManLA | Post - Surround - Video | 7 | 08-01-2014 06:12 AM |
Blackmagic Mini Monitor WORKING with Pro Tools 11 | mattsamperi | Pro Tools 11 | 0 | 11-12-2013 07:44 PM |
