Opening older Pro Tools Sessions
I am trying to open an older Pro Tools project with Pro Tools First but the project file is greyed out and it won't let me select it. I think this was a Pro Tools 7 project and has the .ptf extension. Can this be opened somehow with Pro Tools First?
Re: Opening Older Pro Tools Projects
No, unfortunately PT first uses cloud based "Projects" rather than normal PT "Sessions". If it's not in your cloud account, PT first wont open it.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Thanks for the reply. Any other way to open older Pro Tools projects in another program? I no longer have Pro Tools.
You may need pro tools 10 or earlier. (If Sound designer II files)
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Best way is to export each track that you have on that project, then import them on your choice of DAW. Since they were exported(bounced) they should be aligned on the next DAW you'd want it to be on.
Re: Opening older Pro Tools Sessions
On your PT first window on the left side you will see open.
click on that, on the bottom you will see convert session, click on it and you can import your old session WITHOUT the 3dr party plugin, you can only import 3 project and DONT save the in the cloud. save them local. |
Opening older Pro Tools sessions in Pro Tools 12 | frankrmorrison | Pro Tools 12 | 3 | 12-21-2016 11:17 AM |
Pro Tools 11 Freezes When Opening Older Sessions | saulls | Pro Tools 11 | 4 | 05-04-2016 10:54 PM |
Sessions from older versions not opening in 12.5 | audioman1973 | Pro Tools 12 | 0 | 04-22-2016 11:30 AM |
PT7 crashing when opening older sessions | mwingerski | Pro Tools TDM Systems (Mac) | 4 | 02-18-2006 03:54 AM |
Crashing when opening up older sessions | IO Composer | Pro Tools TDM Systems (Mac) | 3 | 02-25-2005 05:14 PM |
