2012 i5 mini and ProTools 10
Hey all,
I had a 2012 i7 Mini for a short time and it handled pro tools just fine. What it did not do was run cool under load. I have seen some thermal comparison data that the i5 mini runs much cooler under load due to same thermal management as i7 but less TDP. So: does any one have experience with running protools on a sandy or ivy bridge i5? I typically run 16 tracks, 16 channel strips, some waves, delays, a verb as well as BFD and a VI or two. On the i7 machine this averaged a 15% to 20% load and I only allocated 4 cores. My engineering brain says if I allocated 3 cores to PT on an i5 I would get 1/3more load than on the i7 (ie now would be closer to 25 to30%.) If so I am thinking this may be fine for me. Any input on how a modern i5 would fare would be appreciated!
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
Re: 2012 i5 mini and ProTools 10
You're going to have a performance hit going to the i5 Mini. Remember that the i5 does not do hyperthreading. Your comparison between the i5 and i7 machines only holds if they have the same clock speed (and they don't). |
The details of my views on the i7 mini can be found here...
http://duc.avid.com/showthread.php?t=331218 Yes, The i5 is dual core hyper threaded proc. At 2.5GHz though its singe core speed is on par with the i7 2.3/2.6. I did find out that sadly the i5 is a not a quad. This may be too far a fall for protools (as in assign only 2 to 3 cores for pro tools). May be nowhere near enough. But I am sure some of the folks have tried a system like this. Still interested to hear how that went. (edited for technical corrections)
As musicman691 alluded to...
The processor is getting very hot. But... Is it "hot to outside of spec"? Hot enough to damage the processor or other components? Just "getting hot" is not necessarily indicative of a problem...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
The thing for the OP to remember is that NO computer will run cool under loads like we put them under with audio recording unless you're running some kind of massive liquid cooling. They WILL get hot. And some of these machines have chips that are spec'ed to run a lot hotter than any sane person would feel comfortable with but the geeks who design these things must know what they are talking about.
Sadly (for me) I AM one of those geeks...
25 years designing high reliability power supplies... To have the CPU go up to 94degC under 15% loads is just a bit hard for me to get used to. Sure the proc spec is 105. But I can tell you that there are a lot of 85degC components right nearby. Also there are thermal stresses on all the solder joints from the rapid temp cycling and a host of other things I sadly know about. Yes, it is all at least in spec for the CPU so in the end it came down to my feelings about it. I am not saying it won't work, isn't reliable etc... I am saying it is outside my comfort zone. And BTW - there are tons of great thermal designs in the computer world. The MAcPro is an obvious. My CPU temp on my aging 2009 MacPro NEVER goes above 60degC at 100% load. It takes thermal mass, surface area for radiation and airflow. All nuts and bolts engineering from the last 50 years. All of the computers I have built in the past are even better than that... just saying
Is this still true? My 2012 dual core i5 2.5 GHZ macbook pro shows 4 available cores.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ |
2012 i5 in the mini is a dual core hyperthreaded proc. Core i5 3210M. The desktop version is a true quad core with no hyper threading.
2012 Mac Mini, 32 and 64 buffers, HDN Latency | propower | Pro Tools HDX & HD Native Systems (Mac) | 15 | 06-20-2013 03:32 PM |
Late 2012 Mac Mini and PTHD | Siegfried Meier | Pro Tools 10 | 6 | 01-28-2013 09:49 AM |
Mac Mini 2011/2012 ProTools and CPU heat issues | propower | macOS | 24 | 11-28-2012 05:12 PM |
2012 Mac Mini | himynameisdustin | macOS | 1 | 11-22-2012 02:40 AM |
mac mini 2012 can run pro tools ? | smcchris | macOS | 6 | 11-10-2012 05:52 AM |
