Cannot get MIDI controller to work
In our studio we're running PRO TOOLS HD 6.9.2 on a G5 Dual Processor running Tiger 10.4.5.
On my LE system at home powered by MBox I can connect my Kurzweil SP88 as a MIDI controller via an M-Audio USB Uno 1x1 MIDI adapter plugged into my computer. I set up an AUX track and choose an instrument plug-in (Reason Adapted or Symphonique Silver Edition) and it works just fine. However, in our studio HD system, I connect to the G5 and doing all other things the same, I get nothing. My M-Audio does give me a light showing it is connected to the computer and is receiving power; when I hit a key on the SP88 the M-Audio interface shows that it is receiving the signal; in the MIDI section of Pro Tools it recognizes that the M-Audio interface is connected and active, yet when I hit a key it will not trigger anything in Reason or Symphonique. Is there something different with the HD/TDM system than the LE as far as connecting MIDI? Any help would be appreciated. Thanks. |
Re: Cannot get MIDI controller to work
Since 6.9 I've had some midi issues that may be related. I use a Motu usb interface. If I exit PT and do anything else... itunes, firefox, etc. and then relaunch PT, it won't recognize the midi input. The lights on the interface show midi info, but no input on a selected or record enabled PT midi track. Reboot and the world is fine again.
Another odd thing... if a session has all 64 midi output channels in use when opened... same thing happens... no midi input. Selecting an output not in use somehow "turns on" the midi input. I had to redo my orchestra templates to have 63 enabled outputs--- so I can choose the unused output to "flick the switch". Haven't had time to track down the issue further--- just know the work arounds. I'm pretty sure this is usb midi related. Try a reboot--- and good luck. Aubrey
PT 7.4cs2 | OS 10.4.9 | Dual 2.0 G5 7g Ram | HD3 Accel | 4 FW800 Drives |
I did set-up the MIDI preferences in the MAC. Also, I can get the MIDI signal to go into Garage Band, so the issue only appears when I want to use it in Pro Tools HD.
I have rebooted and restarted, re-installed drivers to no avail... Thanks anyway. |
PT6 Reference Manual, pg. 182 PT7 Reference Manual, pg. 188 To enable input devices: 1 Choose Setup > MIDI > Input Devices. 2 In the MIDI Input Enable dialog, select the MIDI devices you will record from. Also, make sure any devices that will be used as a control surface are also selected. IHTH. .
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
I've had a similar problem with my Oxygen-8. I've found that hot plugging the USB connector once protools is launched helps.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired) MBP C2D 2.4/4GigRAM/Mbox/8.0.1 iMac i7 3.4/16GigRAM/10.0.1 |
Go to MacHD>Users>your account>Library>Preferences>By Host and trash 'com.apple.midi.a bunch of numbers and letters.plist'.
Go to MacHD>Users>your account>Library>Preferences and trash 'com.apple.audio.audiomidisetup.plist'. Empty the trash and restart, then see if everything is working. |
Can this Midi Controller work with a Digi 002? | jwd65 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-18-2011 02:28 PM |
Motif Es 7 to work as a midi controller In Pro Tools | mexablcknesekid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-10-2010 10:46 AM |
Can't get my MIDI controller to work | Makingamonster | General Discussion | 1 | 10-13-2009 08:15 PM |
Does Midi usb controller work with protools? | karlomni | MIDI | 7 | 04-04-2007 10:03 PM |
midi controller to work w/ mbox | Jed Zepplin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-29-2004 07:32 PM |
