Edit selection follows Clip list selection [solved]
When i select a clip in the clip list, the edit selection used to go to the point in the session where this clip is used. Thought this setting was "Edit selection follows Clip list selection" but turning this on does not do this. Is there another setting i'm overlooking? Any ideas?
Protools 2019.12, HighSierra 10.13.6, 2x2.66 Ghz 6 Core intel Xeon, 24 Gb 1333 MHz DDR3 |
Re: Edit selection follows Clip list selection
A couple of things that could possibly going wrong.
First, the clip you are selecting needs to be on a visible track in your timeline. This is obvious, and I assume you are aware of this, but just to put it out there. Second, this one got me a couple of times: If the clip you are selecting is nested inside of a clip group, it will not select the clip you want on your timeline. If you were to ungroup the clip, and then select the clip in your clips list, it would then work as intended. I don't know if this is by design or not, but it is the way it behaves. |
Thanks, the visibility of the track was it.
Good to know!
Edit Selection Follows Clip List Selection not working | Sjoberg | Pro Tools 10 | 3 | 12-04-2020 12:38 PM |
Clip selection do not work | Schwerindustrie | Pro Tools 12 | 2 | 11-22-2015 08:40 AM |
Move the selection forward by the selection amount not working in PT10 [SOLVED] | Captain Audio | Pro Tools 10 | 3 | 06-17-2014 10:43 AM |
PT 7.4 HD: Link Edit- and Region List-Selection | Smico | Tips & Tricks | 2 | 10-14-2011 02:54 AM |
Edit Selection Follows Region List Selection->NOT! | alteregg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-14-2006 03:40 PM |
