PluginUpdate: Many Instances of Old '__Pace_Eden' Versions
Hi all,
I'm liking the functionality of PluginUpdate, but one thing's confusing me with it: When I run a scan, it's showing multiple versions of '__Pace_Eden', all with different version numbers. From what I can tell, that's the iLok License Manager, but I've already updated it to the v3.1.7.899 it's listing against them all; not sure why it's saying my installed version is 2.43151727115 and ~30 others! Is there something I should be doing to clear out all these old versions, or anything I can do to stop them showing up in the app? I'm on PluginUpdate v1.0.3 and only scanning the one, standard folder: /Library/Application Support/Avid/Audio/Plug-Ins Thanks for any input!
Pro Tools 2018.1 (Non-HD) | macOS High Sierra | 2.6 GHz Intel Core i7 | 8GB RAM | 7200rpm SATA Drive | iLok Cloud | Line6 POD UX2 | 256 Sample Buffer | 1 GB Cache |
Re: PluginUpdate: Many Instances of Old '__Pace_Eden' Versions
Here's a screenshot of what I'm seeing:
And, as you can see, my iLok manager is up to date:
If I had to guess what is happening is PluginUpdate is searching through the aaxplugin folder contents and finding the version of PACE EDEN tools that the developer of each plugin used when they built their plugin. It has no relevance to the version of iLok license manager actually installed on your system. All AAX plugins must be built with PACE EDEN tools regardless of whether they use iLok or not.
Interesting! Thanks for the insight. I hadn't considered that explanation. Explains how it was finding that stuff at all when there's no actual iLok/Pace AAX file itself in the folder. Frustrating that it clutters PluginUpdate quite so much, but I know it was never fully completed software, and I would assume everyone faces the same issue. So long as it's not something I've done wrong, that is the main thing.
It's ironic but if you do a fresh install of latest pt with just stock air and avid plugins and run plugin update, you'll find they mostly all come up as out of date !
And off the top of my head it's the air ones that display the message you are seeing |
PluginUpdate drops server | TrentWilliams | AAX Plug-ins | 14 | 12-29-2017 01:56 AM |
Pro Tools 11 and pluginupdate | Becharax | Pro Tools 11 | 2 | 02-02-2014 10:06 AM |
2 instances of PT | 77pro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-14-2008 04:45 PM |
Oxford EQ instances: How Many?? | AW studio | Pro Tools TDM Systems (Mac) | 7 | 03-14-2004 05:58 AM |
Dsp instances? | MusAx | Pro Tools TDM Systems (Mac) | 2 | 12-16-2000 12:49 AM |
