Old 08-29-2017, 12:23 AM
Audioartist Audioartist is offline
Default Eucon fixes
PFL solos cancels when I switch between layouts, very annoying.
But it doesnt cancel if I am in AFL.
(PT 11.3.1 + eucontrol 3.6)
Would it be possible for an option to set that the shift button on artist series never latches?
Not possible to set EQ3 hpf / Lpf slope in the control app.
Can you fix so that the eq3 and Dyn3 mapping is the same in both EQ/Dyn and insert mode?
D-control ES 32 - Venue Profile 48x24 - S3L-X - Yamaha DM2000 - Artist mix and control - HD7 accel - HDX2 / Magma EB3T
HD native thunderbolt
PT10HD 10.3.8. - PT11HD 11.3.2
2xHD madi - 2xHD omni -
Old 08-30-2017, 11:44 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Re: Eucon fixes
I will get this fixed...doesn't do this on S6
Yes but not high priority at the moment
Its on the second page, works OK here (in latest software PT 12.8.0, EuControl 3.6.1)
Yes this is something we are looking at across all surfaces for the next release hopefully
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
Eucon 3.6.1 - eMix 6.1.0 - No Eucon channel meters Rpro System 5 14 08-04-2017 11:20 AM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 10:09 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
