No playback sound using Mbox mini 3
After being away from recording for a couple of months I suddenly find no sound on playback through my MBox mini 3rd Gen. I checked settings input output etc. and followed a few checks advised on line with no effect. I also downloaded the latest MBox driver update (package 1.1.7). Now Pro tools 9 hangs up on loading with the message 'The selected ASIO audio device could not be initialized. Please choose another audio device.' Can anyone suggest a solution please.
Re: No playback sound using Mbox mini 3
More details might help(only reason I know you run a Windows machine is the mention of ASIO). This might be worth a try:
Disconnect the Mbox. Go to Control Panel>Uninstall a Program uninstall the Mbox driver Find the driver download and right-click and select Run as Admin Once finished, shut down, connect the Mbox and reboot. With any luck, you will see the popup about "New Hardware Found....." Hold the N key while opening Pro Tools, which will take you directly to the Audio Engine selection page. If you CAN select the Mbox as the audio engine, that SHOULD do it.
Mbox Mini 3 Playback Summed? Cannot Pan. | ZachMoore | FireWire & USB Audio Interfaces (Win) | 7 | 09-09-2013 04:40 PM |
Mbox Mini 3G Playback Distortion | norwenna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-18-2013 03:01 PM |
Mbox 2 Mini & PT 9 - can't hear playback HELP! | benparker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-18-2011 07:29 AM |
Using Mbox Mini as a playback device, a little help? | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-11-2009 07:47 PM |
Mbox 2 mini. DRIVERS sound/no sound | HotLava | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-17-2008 06:52 AM |
