#41
Re: The o'l CPU overload/increase H/W Buffer Size (error AAE-6101)
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
#42
No offence, but what you were doing was not a solution for me. Theres no way in the world I would be doing that after every launch of Pro Tools. Removing files from the .pkg file is a decent workaround if it works and doesnt alter anything. Its always a bit scary doing that. Who know what checks theyve put in place. Sent from my iPhone using Tapatalk |
#43
Forgive the potentially stupid question...
What do you guys use for a click track now you've removed it??
James Welch Recording Engineer | Producer Masterlink Productions Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire) macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24 |
#44
Good questions, you could do your own click track by importing a click sound copy it for a measure and than duplicate that measure for the length you need it.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 |
#45
I would sure miss being able to press 7 on the keypad to turn it off!!
#46
Create some intrument track (Structure for example), In the transporter double click on the metronome icon, in the output box select Structure and enter the corresponding notes for accented and unaccented, velocity and duration, for greater convenience save as a Track Preset
Mac Mini 2018 Mac OS Ventura UA Apollo Twin Duo Pro Tools 2024.3 |
#47
As for what was described by ferrerh all your doing is removing a file the .pkg looks at when PT loads. I would say there is a lil macro that runs checks the plug-in folder against the list core plugs it has in it contents package folder named “core plug-ins” and throws a copy in if one is missing. All you are deleting in there is a copy of the click plug itself..... “Clickll.aaxplugin” the very same file you kill in the plugs folder.... it’s cool if you’re uncool with that.... all good mate. Actually I’m willing to bet you could place any plug in that core plug folder and it will then be a core PT plug on your system.
#48
Yeah like ferrerh said create an instrument/midi loop.... and you can use real drum sounds, save as a preset.... and they’ll stretch or shrink with what ever tempo where an audio won’t without sounding crappy.
#49
I didnt state you said it. I was merely commenting on the solution you responded to. Ive done package modifications before for many years, but not being a coder, I still stand by that we dont know exactly what may or may not be happening. Im sure it will be fine, but its still a risk. Sent from my iPhone using Tapatalk |
#50
You are a GENIUS Sent from my iPhone using Tapatalk
Increase buffer size Error.. -_- .. | changareth | macOS | 4 | 02-09-2011 08:50 AM |
Increase Buffer Size Error (Buffer at MAX) ??? | PoPimp3069 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-29-2010 02:24 PM |
increase H/W buffer size error | dgrim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 07-08-2009 04:50 PM |
Increase buffer size error | toddw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-19-2008 02:05 PM |
Help! "Increase Buffer size" error | therigaletto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-17-2008 05:25 PM |
