Having a HUGE problem with going from HD1 to HD2 !!!!!!!
whats up everyonei? we are having a problem with one of our studios.....the mac is a G5 10.5.8 2x3 Dual Core 2gb RAM.PT 8.0.1 HD Accel PCI-E......
so we wanted to go from 1 Accel card to 2 accel cards.....it runs ok with one card...but when we put on the 2nd accel card in to the magma we get a error saying DIGIDESIGN IS UNABLE TO LOCATE ATTACHED TO HD BLAH BLAH.... we tried 2 different accel cards and it didnt work with either one of em...but when we get back to only 1 accel card, Pro-tools starts working.... Does anyone have a clue???? Whats up Digi??? |
Re: Having a HUGE problem with going from HD1 to HD2 !!!!!!!
everything is connected? flat cable from B to A? Core card is installed on magma too? post more info, maybe we can help you...
Mix Stage 1 PT HDX Ultimate 2022.12 D-Control HD I/O Hackintosh i9 12900K 32 Gb RAM OSX 12.6.7 Mix Stage 2 PT HDX2 Ultimate 2023.6 S6 MTRX I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 Mix Stage 3 PT HDX Ultimate 2023.6 D-Command HD I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 ADR PT MBox Studio Ultimate 2023 Mac Mini M1 8 Gb RAM OSX 13.4.1 Edit 1 PT HDN PCIe 2023.6 96 I/O Intel i7 6700K 32 Gb RAM.OS Windows 10 Estúdio JLS Facilidades Sonoras São Paulo - Brazil |
yep the core card is installed on magma and the flat cable is connected the right way!!!!! =(((( its driving me crazy...
Is your core card the one closest to the PSU in the Magma? If so, you may have a bad flex cable or even Core card. Try to swap it with a different core card from one or your other rooms if you can.
g'luck |
This is a message from digitest or when you start pro tools? maybe magma slot is not ok. Try to install core and accel inside Mac, just for a test, if it works, you can discard board problem... or try installing cards after slot 2 on magma...
delete prefs
change the order of the cards, try A to B and also B to A (you have to change the digilink-cables/priority too.
Selling: |
That bit of a message you typed sounds like the error you get when an interface attached to the first card isn't located. Are you sure you have your interface cable connected to the first / core card? I've seen someone get this message when the flex cable is reversed, I know you said you checked...but double check! Also, did you run Digitest?
any news, s.w.a.t?
HUGE Problem with HD 8.0.4 maybe ADC??? | smilerecord | Pro Tools TDM Systems (Mac) | 0 | 08-19-2010 08:35 AM |
I have a huge Problem!!! please help! | moisesgalvan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-15-2008 06:34 PM |
i have a huge problem!!! please help! | moisesgalvan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-15-2007 04:51 PM |
I have a Huge Problem!! | Jesus H. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-19-2005 11:00 PM |
HUGE PROBLEM!!! PLEASE HELP!!!! | juneaudio | General Discussion | 3 | 12-21-2001 12:45 AM |
