Old 07-25-2011, 06:17 PM
drasmith drasmith is offline
Default Blasts of White Noise & Pops
About 2 weeks ago and about 3 days before I installed the 9.0.3 my PT9 started hanging, crashing, quitting partway through the startup and now...it starts but about every 15 seconds I get a huge blast of white noise with pops in between.
I'm on a PC.
Anyone have any suggestions? I appreciate any help!
Thanks,
Allen
Old 07-25-2011, 06:19 PM
Default Re: Blasts of White Noise & Pops
We need a lot more info, and ideally a Sandra report. Help us Help You - READ THIS Before Posting!
Old 07-25-2011, 06:28 PM
Thanks Darryl, I'll get on it.
Allen
Old 07-27-2011, 04:49 AM
Red face Re: Blasts of White Noise & Pops
Hope this is what you wanted.
Thanks,
Allen
SiSoftware Sandra
Computer
Model : MSI MS-7235
Workgroup : WORKGROUP
Host Name : User-PC
User : Allen
Processor
Model : Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
Speed : 2GHz
Cores per Processor : 2 Unit(s)
Type : Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : MSI MS-7235
BIOS : Phoenix Technologies, LTD 6.00 PG 06/13/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 8GB DIMM DDR2
Chipset
Model : Intel P965/G965 Memory Controller Hub
Front Side Bus Speed : 4x 280MHz (1.12GHz)
Channels : 2
Memory Bus Speed : 2x 6.18GHz (12.35GHz)
Memory Module(s)
Memory Module : Hynix (Hyundai) HYMP125U64CP8-S6 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
Video System
Video Adapter : Radeon X1300/X1550 Series (PS3.0, VS3.0 445MHz, 256MB 297MHz, PCIe 1.00 x16)
Graphics Processor
Storage Devices
WDC WD4000YR-01PLB0 (400GB, SATA, 3.5", 7200rpm, 8MB Cache) : 373GB (G:)
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (C:)
WDC WD740ADFD-00NLR1 (74.4GB, SATA150, 3.5", 10000rpm, 16MB Cache) : 69GB (E:)
WDC WD1600JS-00NCB1 (160GB, SATA300, 3.5", 7200rpm, 8MB Cache) : 149GB (F:)
SanDisk U3 Cruzer Micro 4GB (USB) : 4GB (H:)
HL-DT-STDVD-RAM GSA-H22N (RAID, DVD+-RW, CD-RW) : 3GB (D:)
Logical Storage Devices
Storage (G:) : 373GB (NTFS) @ WDC WD4000YR-01PLB0 (400GB, SATA, 3.5", 7200rpm, 8MB Cache)
Reserved : 100MB (NTFS)
Ripping (E:) : 69GB (NTFS) @ WDC WD740ADFD-00NLR1 (74.4GB, SATA150, 3.5", 10000rpm, 16MB Cache)
Hard Disk (F:) : 149GB (NTFS) @ WDC WD1600JS-00NCB1 (160GB, SATA300, 3.5", 7200rpm, 8MB Cache)
Removable Drive (H:) : 4GB (FAT32) @ SanDisk U3 Cruzer Micro 4GB (USB)
Hard Disk (C:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm)
RhythmCraft (D:) : 3GB (CDFS) @ HL-DT-STDVD-RAM GSA-H22N (RAID, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller 1 : Intel 82801HB/HR (ICH8/R) LPC Interface Controller
LPC Legacy Controller 1 : Winbond W83627EHF/EF/EHG/EG
Serial Port(s) : 2
Parallel Port(s) : 1
Disk Controller : MSI 82801H (ICH8) 4 port SATA Controller
Disk Controller : MSI 82801H (ICH8) 2 port SATA Controller
Disk Controller : MSI JMB361 AHCI/IDE
USB Controller 1 : MSI 82801H (ICH8) USB UHCI #4
USB Controller 2 : MSI 82801H (ICH8) USB UHCI #5
USB Controller 3 : MSI 82801H (ICH8) USB2 EHCI #2
USB Controller 4 : MSI 82801H (ICH8) USB UHCI #1
USB Controller 5 : MSI 82801H (ICH8) USB UHCI #2
USB Controller 6 : MSI 82801H (ICH8) USB UHCI #3
USB Controller 7 : MSI 82801H (ICH8) USB2 EHCI #1
FireWire/1394 Controller 1 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Peripherals
Media Player : SanDisk U3 Cruzer Micro (3.74GB)
Network Services
Network Adapter : Realtek PCI GBE Family Controller (Ethernet, 1Gbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 3.9
Old 07-27-2011, 05:04 AM
MikeLip MikeLip is offline
disable the net card?
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells
Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized.
Google the DUC
Search Avid
Old 07-28-2011, 03:49 PM
How do I go about that?
Allen
Old 08-09-2011, 06:28 PM
I could not be more embarrassed , but, I shall nevertheless post my "solution". And, yes, I was supposed to be aware of this.
I have an IKMEDIA bundle that most of which I had registered but when I inserted any of the IK plugins into a session, then the expired plugin would give it's white noise "blast"....even if it was not the plugin being used. I have registered them all and ...no problems.
Allen
Old 08-09-2011, 10:43 PM
Well done troubleshooting it yourself. A+, Sir.
Mike.
Google the DUC
Search Avid
Blasts of white noise and sync errors??! sknoof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 02-05-2010 06:52 PM
Random Blasts of White Noise TNDoug 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-14-2007 10:42 AM
Blasts of white noise in LE systems. Forever? easyb Tips & Tricks 26 02-02-2007 06:38 AM
White Hot M-BOX Noise Blasts! Please Help! Derek Doublin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-17-2004 10:47 AM
Protools 6 white noise blasts - little help? roryrok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 29 03-07-2003 11:40 AM
