Old 08-28-2015, 09:13 AM
mesaone mesaone is offline
Default MetaPlugin update - support for fxb/fxp, plus new 64-channel external routing tool
From the email I just received:
Dear Metaplugin user,
a new version is waiting for you at http://www.ddmf.eu/register.html . If you have already applied the license file in a previous version, just download the installer and install the plugin; otherwise, download the license file too.
What's new? There's now fxb/fxp support for VST plugins, which means you can load such files via the "load" button of the plugin window. This should improve cross-DAW-functionality even more.
And: there's a new helper plugin, called SendIt... it can send and receive audio data on up to 64 channels (with one send/receive pair per channel). With this plugin you can, e.g., easily bring sidechain audio data into Metaplugin. Just load a send instance of SendIt on the track you want to send, and a corresponding receive unit in Metaplugin on another track. Under ProTools, you need to place one instance of Metaplugin with SendIt inside on the send track (instead of just the bare SendIt... SendIt is not available in AAX format, as it's not possible to load AAX plugins into Metaplugin).
I hope I have not confused you too much, just try it out and if you're happy or unhappy, I'm waiting for your feedback!
Cheers, Christian
So the new SendIt component opens up external sidechaining, and additional parallel processing opportunities. If you're unfamiliar with FXB and FXP files, they are patch settings (and banks) for VST plug-ins. This should allow parity between DAWs, as it is simple to export a FXB file from one and import into MetaPlugin.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
HTML code is On
Eleven Rack song update - Added a solo! Variable Eleven Rack 7 11-06-2011 05:59 PM
Why is Pro Tools so unstable? Why is support so bad? Update Sandra report added Robert Todd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 02-12-2011 02:29 PM
Is the patchbay the best/only tool for routing cables? Raymond Hardy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-24-2003 07:03 PM
