Old 06-16-2015, 04:17 AM
made made is offline
Default S3 EQ "Band In" keys don't update properly
this might be a bug, so maybe some other S3 user could confirm:
-make session with two tracks
- put Channel Strip or EQ7 on both tracks (might happen with any other EQ)
- set tracks into "latch" and make a selection on the first track
- go into playback and disable some bands on the S3 (In keys leds go off) and write that to the selection
- now attention track two -> the "In" lights are on
- place the cursor somewhere after the selection you've written earlier.
-then place the cursor inside the area where you've written automation earlier and attention the first track. "In" lights are still lit, but the bands are off in the EQ...
this is on PT12HD with latest Eucontrol and S3 firmware on Yosemite 10.10.2
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78)
LIO-8
BlackmagicDesign UltraMonitor3G
Reaper 6.66, Fireface UCX
MacbookPro M1Pro PTHD2021.12 MacOS12.1
MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB
Old 08-19-2015, 03:00 AM
Default Re: S3 EQ "Band In" keys don't update properly
EQ band parameter LEDs are still not working properly in Eucon 3.3
this is the same on Artist Mix...
LIO-8
Old 11-10-2017, 05:17 AM
this seems still true in 12.8.2 Eucon 3.7
LIO-8
"Save Session Copy In..." not working properly Meads Pro Tools 11 2 07-20-2013 09:15 AM
Keep getting "application failed to initialize properly 0xc0000005" georgeearth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-23-2011 08:16 AM
"Save Copy In..." Never Works Properly! reichman Post - Surround - Video 21 11-12-2008 09:54 AM
error msg "your equipment isnt installed properly" after xpand update yanncrusoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2008 03:55 PM
hard disk problem - help! "B Tree keys out of order" Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-16-2002 06:27 AM
