Old 09-19-2019, 10:04 AM
skilletaudio skilletaudio is offline
Default Double Tape Assign to Copy Tracks from Banking Mode into Current Layout - Bug
I love the option that has been added to "Double Tape Assign to Copy Tracks from Banking Mode into Current Layout." However, it seems to follow the prior behavior before Virtual Strips was added. It always stops at the number of faders I have and doesn't follow my virtual fader setting so I have to add the extra faders in manually each time. This is more of a safety thing to have the assurance that what I see in Pro Tools is what is going into my layout.
I especially use this for interrogating track I/O to make sure I have all the tracks that relate to those paths.
Anyway fixing this bug or adding this feature would be greatly appreciated!
Old 09-19-2019, 10:18 AM
creativecontrol's Avatar
Default Re: Double Tape Assign to Copy Tracks from Banking Mode into Current Layout - Bug
I’ll examine the current behavior and report back.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-20-2019, 06:10 AM
EddieJones's Avatar
Are you saying that you have your virtual layout set to bigger than the number of faders and when you do the copy it only puts the tracks from whats on the surface into the layout ? If so that is working by design as there are no other tracks on the surface to put in the Layout. I can see why you would want it filled though.
Old 09-23-2019, 10:02 AM
Thanks, Jeff and Eddie for your replies. To answer your question Eddie yes I guess what I was thinking was I want to show all the tracks for that path and quickly put them into a layout. I just thought since I could bank them it would fill up at least the number of virtual tracks in the layout but I guess that is not the case. Is there another way around this to quickly assure the accuracy that I have all the tracks that belong to that layout?
In Pro Tools, I can right-click on a bus and choose "Show Only Assignments to Internal Layback - Pro Tools Mix" for example. Then in tracks view it shows only those tracks. Is there a way to choose "Select All" in Tracks Assign mode I can select one and then get the option to "Select None" but option clicking, shift-clicking under settings button or on the faders doesn't give me an option or select all.
I'd just like to ensure accuracy and speed in setting up these layouts.
Old 09-23-2019, 02:11 PM
Thanks for the feedback. We’ve certainly had other users convey a desire for selecting and populating a collection of tracks from the PT UI into a Track Layout.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-23-2019, 06:43 PM
Thanks Jeff, I appreciate your positive feedback.
Old 04-12-2024, 02:24 PM
Is there any possible progress forward on this, or perhaps I missed it in an update?
Old 04-15-2024, 09:09 AM
EddieJones's Avatar
Sorry not yet.
No option to stop PT banking tracks whilst banking on S3 bassmagnetic Avid S1, S3, Dock and Control App 2 05-30-2019 10:10 AM
PT does not follow S3 Banking when in VCA Master Mode bobbyguelz Avid S1, S3, Dock and Control App 19 11-09-2018 01:49 PM
Mixed mode LAYOUT / BANKING ? kava Avid S4/S6 8 07-08-2015 08:47 AM
Layout of the channel mode OLEDs made Avid S1, S3, Dock and Control App 0 02-23-2015 03:18 PM
banking through flip mode ec123 ProControl, Control|24, Command|8 1 01-02-2008 07:34 PM
