Old 07-09-2014, 03:45 AM
maxx.monopoli maxx.monopoli is offline
Default HD I/O cards sequence/layout
I own an HD I/O with following cards:
- 8ch analog In
- 8ch analog Out
- 8ch digital I/O
plugged in this order:
Besides PTHD11, I'm using the HD I/O as audio interface with Logic Pro X (via HDX) as well.
LPX needs the main stereo out to be the channels 1-2 of the interface, but actually HDX passes the analogue I/O ch 1-2 to LPX as channels 1-2 (over the 16 I/O channels which are passed through HDX driver).
Should I swap the positions of the digital I/O card with the analog Input card in order to have HDX passing the digital ch 1-2 as first and second channels to Logic X (so they become main "Stereo Out" in LPX)?
Is there any specific position sequence for the expansion boards?
Or I can I just swap them without problems?
Thank you for your replies.
Maxx
Old 07-09-2014, 07:58 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: HD I/O cards sequence/layout
Don't change the cards. Your I/O settings and Hardware setting should get you the combo you need.
(Help us Help You)<<<click here
Old 07-09-2014, 07:43 PM
jbrown7282 jbrown7282 is offline
Agreed... No need to change...In your CoreAudio Application make sure that the outputs are leading to the right output for Logic...
Jay
Litehousemuzik
Audio Mixing Services
Studio Layout NativeLuv17 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-16-2008 06:42 AM
mixer layout JoeQ Tips & Tricks 4 10-27-2004 03:52 AM
C24 mic pre layout darla ICON & C|24 0 07-29-2001 10:01 PM
Control 24 d-sub pin layout kennylarkin ProControl, Control|24, Command|8 3 03-28-2001 09:04 AM
PCI card layout for Mac audio101 General Discussion 1 01-25-2001 09:02 AM
