Old 06-04-2013, 10:59 AM
audiofreak11 audiofreak11 is offline
Default 44.1 or 48 if audio is imported?
Hi!
I do mostly importing and exporting of audio files from others, for use on terrestrial radio. I do record at times, but it's not often, and it's just simple VO. I basically produce using audio sent to me, then send the finished product back to a client, usually as a WAV or mp3, and for one client, an AIFF.
Most of the files I receive and import into my sessions, are 44.1 mp3's. I've sifted through discussions about what settings to use when you record audio, but wanted to ask your thoughts about bit rate/sample rate when using audio already set at 44.1.
Is there any benefit to setting a session up higher than the original audio I will import into it? Would a session at 24/48 be any better than one set at 24/41 or 16/41, if the audio I am importing is a 44.1 mp3. Does it help me have any more dynamic range, or am I just wasting space on my Mac?
Is it better to just ask each radio station what their system handles on-air and match that as my session and bounce settings? Or can I go higher for improved audio?
Hopefully this isn't too stupid of a question, but I want to be sure I am working as efficiently as I can. I appreciate your help!
Regards,
Chris
ProTools 12.7
Mac OSX 10.12.2
Intel iMac 3.4GHz i7 (late 2012) with 32GB RAM
Digi 003r
Old 06-04-2013, 11:05 AM
Default Re: 44.1 or 48 if audio is imported?
My 2 cents only, but considering your "market", which is radio broadcast, I doubt there would be any value in up-sampling. With the typical heavy limiting, and the limited bandwidth, I would stay at 44.1(although I do like the extra headroom of 24 bits).
Old 06-04-2013, 11:58 AM
Ok cool. Thanks! If I do use 24/48 for my session and then bounce to 24/44.1 for a WAV or 16/44.1 for an mp3, will I risk having audio issues with the final file? I guess it'll get smashed anyway when it's on the air, but I want to at least have it as clean as possible going to them, ya know?
Regards,
Chris
ProTools 12.7
Mac OSX 10.12.2
Digi 003r
Old 06-04-2013, 12:01 PM
cwsand's Avatar
cwsand cwsand is offline
I agree with Albee, unless you're mixing on an analog console you might as well stay at 44.1. The bit rate determines the dynamic range, not the sample rate. There's no harm going to 24 bit in Pro Tools, though you may need to dither when bouncing back to 16 bit.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2020.9
Old 06-04-2013, 12:04 PM
cwsand's Avatar
I'm not actually sure if radio typically plays compressed files these days or not - that is "data" compression, not dynamic compression - they definitely use heavy limiters on the audio. I was always under the impression that they played CD quality files. Anyway, your best bet IMHO is to stay at 44.1/24 bit in Pro Tools and bounce down to 44.1/16 bit for radio.
Help Us Help You
Chris
PreSonus Digimax LT
Pro Tools HD 2020.9
Old 06-04-2013, 12:30 PM
Yeah that makes sense. Thanks so much to you both. I appreciate the input.
Most stations have their own individual settings so there is no guarantee it'll sound like the original when they play it, plus many stations still load audio in analog. But this will help me ensure they get something good and clean going in.
Thanks guys!
Regards,
Chris
ProTools 12.7
Mac OSX 10.12.2
Digi 003r
Old 06-04-2013, 10:25 PM
JFreak's Avatar
JFreak JFreak is online now
Nobody knows what kind of "black box" the station is using, but as a rule of thumb -- if you want your material to sound punchy, you better leave lots of dynamics to the final mix. Those black boxes tend to work better with dynamic material and if you push the limiter too hard it's going to sound wimpy.
Janne
Old 06-05-2013, 12:56 PM
AAh, ok, that's good advice JFreak. I tend to process the VO to make it punchy, and then will try to keep the limiting/compression to a minimum on the master track, so there is more dynamic range in the final audio I send.
Thank you!
Regards,
Chris
ProTools 12.7
Mac OSX 10.12.2
Digi 003r
Old 06-05-2013, 01:16 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Yes, you've gotten good advice. Quality will not improve at all if you up convert a 44.1 file to 48 or even 96.
I'm sure "radio" gets everything. ISDN live shows can be of many compressed formats. MP3 files are everywhere. 44.1 and 16 bits WAV files will work everywhere.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-05-2013, 08:33 PM
Awesome. Thank you!
Regards,
Chris
ProTools 12.7
Mac OSX 10.12.2
Digi 003r
Imported Video doesn't contain audio DavidDubber 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-13-2010 10:54 AM
distorted imported audio caulto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-09-2008 09:28 AM
imported audio is distorted mixit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-19-2004 08:45 PM
OT......... iMovie and imported audio Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-25-2003 09:31 AM
Imported Audio Syncing??? ronev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-29-2003 12:57 AM
