Old 06-05-2011, 05:36 AM
sweetambition sweetambition is offline
Default Imported Audio Duplicating
When I go to teh workspace then select drag and drop audio files,
In the regions section it has a L & R for each audio. and then save this in the audio folder.
How do I stop pro tools from duplication my audio intput and for it just to take the audio from the folder I imported from, not make more copies..
Thanks
Old 06-05-2011, 12:13 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Imported Audio Duplicating
It's not a duplication. Pro Tools does NOT work with stereo interleaved files. When you drag and drop a stereo interleaved file to a stereo track, it's left (L) and right (R) components are separated out.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 06-05-2011, 10:49 PM
Thanks..
so just to clarify there is no way to stop this.. cause I end up with the original fiels I imported as well as the L&R ones.. this takes up a cazy amount of space..
Old 06-06-2011, 11:43 AM
The Weed's Avatar
Are you saying that you want the files from the Folder you are importing from to be deleted when the file is imported into Pro Tools so, instead of the original file and the L/R files in the Pro Tools Audio Folder in the session you only have the L/R files?
Sorry, AFAIK, that's not how it works. The original is kept and a new L/R audio file is created.
Two suggestions: 1) buy a bigger hard drive and/or 2) delete the originals yourself.
Personally, I would buy a bigger hard drive since there's no way I want to delete/change the original files just in case, for whatever reason, I need to go back to them.
Cheers,
Old 06-09-2011, 12:24 AM
k Thanks for this.. I know pro tools takes up a crazy amount of space.. saving for a bigger storage set up!
Best
Sweet Ambition
duplicating audio regions on the grid marcnyc Pro Tools M-Powered (Mac) 1 07-08-2010 04:11 PM
Duplicating or Repeating Audio spidey901 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-05-2007 11:57 AM
Duplicating audio data while retaining automation Kahli Burke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-14-2005 07:30 PM
Duplicating/copying audio to grid Luke Annett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-19-2005 08:42 PM
duplicating an audio region exactly on the grid goom Pro Tools TDM Systems (Mac) 66 06-15-2005 08:34 AM
