Old 03-17-2007, 06:03 PM
almathecat almathecat is offline
Default 003 spdif mirroring
could someone tell me what's going on with spdif mirroring and the 003r?
i just got mine, and the guide proclaims (in the digital i/o section of ch 8):
"the s/pdif output channels always mirror the main outs 1-2."
this statement would seem to be not true in any way,
though i really want it to be.
obviously you can assign multiple outputs in a session (and HAVE to, to get mirroring in the case of
this box, apparently).
the option to turn on spdif mirroring in digi core audio manager is not available. next to it's sad greyed-outness
it says 002r only. and i'm not sure how to take that. the guide would suggest it's not available because it's already going on,
but as noted this is not its default state.
as discussed, this is of no consequence in protools sessions, but it sucks (it actually more than sucks, it makes me insane) that i cant get the output of my computer on spdif (itunes, standalone intsruments, whatever).
i hate to jump to conclusions, but why do i have a feeling this is another one those bizarre design oversights (like the ones that just made me send back an mbox pro: no firewire 800 support, no clocking above 48k on digital input)? why why why??????
please somebody tell me you can turn on spdif mirroring!!!!!!!!
Old 03-20-2007, 12:59 AM
peppertree peppertree is offline
Default Re: 003 spdif mirroring
bump...important! This ought to work...
And btw, did you actually get a 003 from the retail channel already? Still waiting on mine...
`My name is Pro Tools HD, King of Kings:
Look on my works, ye mighty, and despair!'
Nothing beside remains. Round the decay
Of that colossal wreck, boundless and bare,
The lone and native DAWs stretch far away.
Old 03-20-2007, 01:43 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Found this from Digi:
S/PDIF outputs 17 and 18 are "unavailable"
S/PDIF Mirroring is enabled.
When enabled:
S/PDIF digital output is "mirrored" and output on 1 & 2 in the output dialogue box.
When disabled:
S/PDIF outputs separately to outputs 17 & 18 (ADAT mode in the Optical Format Box) or 9 & 10 (S/PDIF mode in the Optical format Box) in the output dialog box.
*Remember to always reset I/O Labels after any changes are made to these settings.
To set up a digital send to an external device from
a Digi 002 or Digi 002 Rack system:
1 Choose Setup > Playback Engine and choose
the peripheral.
2 Do one of the following:
• If the external device is connected to the
S/PDIF RCA jacks, deselect S/PDIF Mirror-
ing. (When S/PDIF Mirroring is on, digital
output at the S/PDIF RCA jacks exactly mir-
rors the output of analog Channels 1–2.)
Optical ports, choose a format (most likely
S/PDIF for an effects device) from the Opti-
cal Format pop-up menu.
3 Choose Internal from the Clock Source pop-
up menu.
4 Click OK.
5 Optionally, configure the I/O Setup dialog
with new path names for effects routing.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
SPDIF mirroring with the 001 wallace1977 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-20-2006 12:54 PM
spdif mirroring yeahyeah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-11-2005 10:56 AM
spdif mirroring -here at last ? kite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-04-2004 07:54 AM
SPDIF Mirroring??? john bradshaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-08-2003 06:15 AM
002 and spdif mirroring ...how ? kite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-22-2002 11:37 AM
