HD I/O cards sequence/layout
I own an HD I/O with following cards: - 8ch analog In - 8ch analog Out - 8ch digital I/O plugged in this order: foto.jpg Besides PTHD11, I'm using the HD I/O as audio interface with Logic Pro X (via HDX) as well. LPX needs the main stereo out to be the channels 1-2 of the interface, but actually HDX passes the analogue I/O ch 1-2 to LPX as channels 1-2 (over the 16 I/O channels which are passed through HDX driver). Should I swap the positions of the digital I/O card with the analog Input card in order to have HDX passing the digital ch 1-2 as first and second channels to Logic X (so they become main "Stereo Out" in LPX)? Is there any specific position sequence for the expansion boards? Or I can I just swap them without problems? Thank you for your replies. Maxx |
Re: HD I/O cards sequence/layout
Don't change the cards. Your I/O settings and Hardware setting should get you the combo you need.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Agreed... No need to change...In your CoreAudio Application make sure that the outputs are leading to the right output for Logic...
Jay Litehousemuzik Audio Mixing Services |
Studio Layout | NativeLuv17 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-16-2008 06:42 AM |
mixer layout | JoeQ | Tips & Tricks | 4 | 10-27-2004 03:52 AM |
C24 mic pre layout | darla | ICON & C|24 | 0 | 07-29-2001 10:01 PM |
Control 24 d-sub pin layout | kennylarkin | ProControl, Control|24, Command|8 | 3 | 03-28-2001 09:04 AM |
PCI card layout for Mac | audio101 | General Discussion | 1 | 01-25-2001 09:02 AM |
