Old 03-14-2019, 03:22 AM
simonchase simonchase is offline
Default Multiple offline bounces of a single reverb instance
Rather convoluted question coming up:
If i have 16 busses. (Drums, bass, vocals, etc etc)
I can do one quick offline bounce with 16 bounce sources and quickly make 16 stems.
But if I have an aux track with a reverb on it that all the busses send to I need to do 16 separate passes to bounce out 16 versions of the reverb. Or make 16 identical reverbs.
I'd love the option to be able to bounce automatically 16 results of one master reverb chosen by the various reverb input sources. (I'm aware that i could be explaining this better)
Anyone got any clever tips for this?
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 03-14-2019, 06:04 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Multiple offline bounces of a single reverb instance
Not clever but you could set up 32 buses, 16 w/out verb and 16 with, bounce the 16 without into 16 new tracks, disable everything but the new tracks and the aux with verb and bounce again. Never had to do this so hopefully someone else has a more elegant solution.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 03-14-2019, 06:46 AM
daeron80 daeron80 is offline
Nature of the beast. It would be possible for Avid to add a feature detecting multiple sends and automatically doing the stems one by one for you. But any way you go about it, you could get slightly different results on each bounce if the verb has any modulation in it.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 03-14-2019, 07:21 AM
Unless it's a *very* simple mix and stem requirement, I usually go with the multiple reverbs route so I can print all stems at once. Having to bounce each stem individually is way too time-consuming.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 03-14-2019, 08:42 AM
arche3's Avatar
arche3 arche3 is offline
Easiest is 16 identical reverbs. Then just one pass of bounce.
Sent from my SM-G975U using Tapatalk
THANK YOU for multiple audiosuite instance! caseyholford Pro Tools 12 7 04-04-2019 12:36 PM
Multiple Instnaces of VIs vs. multiple MIDI tracks targeting a single instance? kirkbross Pro Tools 2018 4 10-17-2018 05:30 AM
Multiple instruments in a Play instance Scott.Brownlee Pro Tools 2018 5 07-06-2018 05:19 PM
Multiple outs on one Falcon instance? Voideco Pro Tools 12 37 07-20-2017 10:19 AM
Why does a single instance of MachFive 3 choke PT 12.2? EricWillhelm Virtual Instruments 4 09-20-2015 11:23 PM
