Old 06-19-2009, 04:12 PM
right beside right beside is offline
Default flight case for the 003 desktop
i need to take my 003 overseas by plane. it is the desktop version. does anyone where to get a flight case that will fit it?
Old 06-20-2009, 11:02 AM
Default Re: flight case for the 003 desktop
Sounds like a question for Sweetwater. Any of the custom case companies will build one. You might also look into a Pelican case. They can be filled with the foam that you pick apart and travel quite nicely.
Old 06-20-2009, 11:12 AM
BradLyons BradLyons is offline
Off the top of my head, this is the only product that comes close---although it will be slightly big, however you can put foam in there (as suggested above) to fill it in:
http://www.sweetwater.com/store/detail/GMix20x25/
You could get one custom-made if you can't find one that fits, but that will most likely cost more money. I believe the dimensions are around 19.5" x 19.5" x5.5" or so on the 003 Mixing Surface, but I'm going off of memory here.
Thank you,
Brad Lyons
www.howavl.com
Wanna see my S3L flight case? Kristo Kotkas VENUE Live Sound Systems 10 04-13-2015 01:24 PM
FS: Pro Tools Flight Case - Nashville Cases - in NY jstraw Buy & Sell 1 07-16-2012 07:19 AM
003 Rack in a flight case - what depth? JasonGough 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-22-2009 04:01 PM
Command 8 Flight case Labyrinth Services ProControl, Control|24, Command|8 4 04-28-2007 01:51 AM
Flight Case for PT systems... TimNielsen Pro Tools TDM Systems (Mac) 3 08-12-2006 09:32 AM
