Re: Using Waves Vocal Bundle plugs to zap mouth clicks
Dave
Pro Tools Editor, Producer, Mixer and Masterer since 1998 |
And here is the original sample I sent to Waves Support, with a representive sampling of the clicks:
http://multiterra.mooload.com/file.p...dra_50.wav.zip This is the corrected version Waves sent me, using the C1 Gate Mono: http://multiterra.mooload.com/file.p...+Sandra_50.wav If you want a longer WAV sample with The Mouth Click, let me know and I'll upload one. BONUS: If any of you out there can get me dramatically better results using Waves Vocal Bundle or any of the standard-issue PTLE 7.1 plug-ins, I'll PayPal you the funds to buy a six pack of the world's finest ale, Deschutes Brewery Mirror Pond Ale from scenic central Oregon! |
I know this might not be a big help for your current situation - 15 hrs of audio without handling a clicking problem? Yoicks! - but here's a trick I use all the time, which I modified basically from a technique used in movie/TV applications: open your mic in your iso booth or wherever you are recording and get things as absolutely quiet as possible (be a NAZI about it if you have to). Record about 30 secs or so of roomtone. When you hear an offending click or even an unwanted breath, paste in a piece of the roomtone that is the same duration as the culprit (sometimes a micro crossfade on either end might be necessary...). Keep the piece of room tone handy in your cut/paste clipboard and use the trim tool to vary its length (duration) to handle different clicks/breaths once you paste in the roomtone. You end up with a really natural sounding recording - though it may take a little more time. Far exceeds any gates, vocal expanders or other plugin functions, no matter how good they are - IMO, they tend to take the 'air' out of a track, not to mention squashing the trailing ends of words many times (it goes without saying to stay away from the strip silence function - arrgh!). Even sraight noise reduction software does it. And just editing out the click or breath can alter the tempo slightly, make someone's cadence seem clipped or abrupt, or worst, just leave behind silence - in any case, even if no one can put his/her finger on it, the track runs the risk of just not sounding 'right'.
I even find that if a click happens in the middle of a trailing end of a word, especially a plosive or velar plosive (like 'k' or 'g' at the end of a word) - which many times is a result of quick tongue movement or 'spit squelch'(I call it) - a small sample of roomtone gets rid of that click while not resulting in an attenuation of the trail of the word (I'm talking durations of .004, .006, or shorter here). IMHO, this technique is far superiour to pretty much any plugin - the character of the room is maintained, and no coloring from the plugins modifies your recording. And, you'll be surprised how quickly you can get at finding and editing these nuisances. The tip of lots of water and kleenex is indispensable. Also, don't forget a green apple (sour granny smiths are best). Ask the talent to chew (swallowing is optional - though not might be a little gross! apple spit cup...?) a small bite - doesn't need to be much. I swear it works wonders! Anyway, just a couple cents worth. Hope this helps. Cheers Nathan Lowe
Studio: Mac Mini 2.6 GHz i7 16GB RAM PT 2019 and 10.14 UA Apollo Quad Outboard: 2 x Summit Audio 2BA-221>TLA 50>EQF-100 2 x dbx 165a 4 x Shadow Hills GAMAhttp://humpbackmedia.net[/SIZE] |
You will probably have to do it manually. You can try to find all mouth clicks by a) stripping silence and then listening to all starts, tweaking accordingly b) using "tab to transient" to find clicks and then cutting them out c) listen to it through without trying to save time and do what was suggested above
Its incredibly expensive, but I think this is the kind of thing you could use:
Renovator Maybe the demo will let you use it on the problem project.
They did. They sent me a preset for RChannel as well. Didn't get the time to test it last night but will tonight.
Wow, Renovator looks like just the ticket, but our little startup could never afford it. The demo only works on three minutes at a time, so that's more trouble than it's worth.
Listening to the Wav.
I would say her head is down reading, and the saliva is collecting behind the lips. She needs to be drinking a lot more water to be a narrator. The clicks and noises are a endemic process of voice work, if someone knows what they are doing they will hear these noises in the cans as they reading. Another way of helping to reduce these noises is to supply a desktop music stand so the scripts can read as people look across. She has a very nice voice, and the xps file does seem to work ok in C1 gate, it is a long process of having to do this every time you record though? Learning curves are a fun thing are they not?
How do I remove Waves Vocal Bundle? | Bryan Cook | Pro Tools TDM Systems (Mac) | 5 | 04-02-2007 11:27 AM |
Waves Vocal Bundle | boostedrsx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-10-2007 08:01 PM |
Waves Vocal Bundle 1.1 - PT7 compato - available | jeremyroberts | Pro Tools TDM Systems (Mac) | 3 | 01-11-2006 08:25 AM |
Remove mouth "clicks" from vocal track? | tysonjm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-25-2005 12:56 PM |
Your Favorite Vocal Plugs...Do You Use The Waves Ren. Vox or Waves RCL? | Bloux | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-27-2003 04:33 AM |
