Re: Working with HFS+ formatted drives
ExFAT even on Windows... Also probably not a good idea to run on. Should be fine for transferring files between systems.... which is how I would handle this... unless the OP needed to frequently switch back and forwards
How long ago? Any format has danger if the drive is marginal. My config is all SSDs. With SSDs, hosed is hosed regardless of file system. No coming back from any errors, but none so far.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
If you have any concerns about robustness exFAT is the last of these file systems you should be on, NTFS is a pretty decent intent based/hardened filesystem, HFS+ was pretty mediocre, but AFS+ is technically head of the pack. Intent based logging/hardened file system highly optimized for flash storage.
I spoke to Apple engineering (as I am friends with product managers there) -- they said that exFAT was not to be relied on and Apple had no interest in attempting any progress to support that file system (as they were developing both APFS and looking at ZFS.) They have not and would not invest engineering resources into it.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
There was a time when there were problems with ExFAT if drives were formatted on the Mac, but I believe that has since gone away (at least here). Pretty much all SD and flash drives > 32GB are formatted this way, so Apple ignoring any issues would be a problem. Paragon also has an APFS product that I have installed on a Win box, but haven't had the opportunity to test. Yet another cross platform solution.
Are there an problems with using MS-DOS formatted drives for backup? | Ru_C | Pro Tools TDM Systems (Mac) | 7 | 09-29-2011 07:25 PM |
Reading Mac formatted Firewire Drives on my PC | kinglenario | Pro Tools TDM Systems (Win) | 13 | 02-08-2003 11:05 AM |
Atto formatted drives | EHeiberg | Pro Tools TDM Systems (Mac) | 3 | 03-30-2001 09:31 PM |
Drives Formatted With Atto Not Mounting | nrgmusic | Pro Tools TDM Systems (Mac) | 5 | 12-23-2000 11:52 PM |
Using Non-ATTO ExpressPro-Tools formatted drives | Samhein | Pro Tools TDM Systems (Mac) | 11 | 11-10-2000 12:15 AM |
