Can you move multiple Markers as a group?
Had to change the T/C on a film project. Is there a way to adjust the 40+ markers to match the change?
PT 12.7 HDX 2/Mac OS 10.10.5 2012 Mac Pro 3.46GHZ/64GB RAM |
Re: Can you move multiple Markers as a group?
select them. cut. paste. no other way.
hopefully one day this will be possible: http://protools.ideascale.com/a/dtd/...ers/91333-3779
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Can´t an "insert time" at the position, where the TC change happens, with the amount of the change, be helpfull ?
That moves also the markers.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
This isn´t helpful for your problem, but I use a deactivated track where I create empty groups. Then I name the group what ever notes I have for the scene.
Way easier to manipulate later.
Newest Pro Tools on mac & pc. |
??? Please explain your procedure in relevance to moving multiple markers after a TC change.
Click into marker track. Enter 01:00:00:00 into "start" field Enter 01:22:00:00 (or where ever your reel ends) into "end" field. hit "x" Hit "*" (numeric block) enter 02:00:00:00 hit "v" done. Just a simple example. Of course any other offset can be done accordingly. Conformalizer will move all your markers along with the clips when you select the marker track, BTW. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 10-17-2013 at 05:59 AM. |
My Question (???) refers to post #4 (of lode),
the deactivated track with empty groups. This seems to be a trick to have a kind of additional marker track, I use empty midi clips over the duration of a scene for this. Many thanks for explaning moving markers via start/end-entries, until now I only used a less efficient method for cut-paste in the marker track ! But what is the reference to using deactivated tracks with empty but named groups ? And is the idea, to insert time at the place of the TC change for the amount of the change, a good one ? E.g. , an edit to the final cut, "we made scene soandso 30 seconds longer, scene soandso does not end at TC 01:30:00:00 anymore, but now at TC 01:30:30:00". So, inserting 30 seconds of time at TC 01:30:00:00 will move every clip and marker in accordance.
Some people use tracks with clip-groups as "markers" as they are easier to wrangle and you can use the find function on them.
So inactive tracks with clip-groups. Or multiple of them for different dept.-notes. Personally I also use the video-universe (a not very known feature for some reason) to navigate but that has become quite buggy since v10 (http://protools.ideascale.com/a/dtd/...T10/88254-3779) . Hope it got fixed in 11.
I know about using a midi track and empty midi clips as "markers" and (together with) the original marker track.
What is your professional opinion on the "insert time" idea ? (Nobody answered yet)
frank.
How to move all markers? | fsb1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-25-2022 10:50 PM |
Move multiple markers at same time | Studio Studio | Pro Tools TDM Systems (Mac) | 2 | 10-01-2016 08:11 AM |
how to move markers .. | john1192 | Pro Tools TDM Systems (Mac) | 6 | 01-19-2010 11:06 PM |
Group Markers with audiotracks? | Arno Peeters | Post - Surround - Video | 1 | 07-10-2008 05:55 AM |
Is it possible, move a fader group? | tamtamstudio | ProControl, Control|24, Command|8 | 5 | 12-16-2003 05:35 PM |
