#31
Re: LtRt AAX plugin
Most places I know of are taking 2.0 Stereo (LoRo) instead of LtRt (1 or 2)these days.
Randall Quote:
Randall Smith Audio Editor/Mixer Starz Entertainment Group Denver, CO |
#32
Re: LtRt AAX plugin
Indeed it works with Dolby Atmos Production Suite but it's a bit tricky, there is a delay (less than one frame) while you rec the file inside Pro Tools and you can't decode the LtRt.
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 12.7.3 - Ram 64G - PT Ultimate 2024.3.1 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround) |
#33
Re: LtRt AAX plugin
I think this thread is about which plugins can be used to encode an LtRt, not about if LoRo is better, right?
Cheers Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D ------------ mars13.de |
#34
Re: LtRt AAX plugin
I think you waste your time by answering this way. And in this thread there were already opinions about LoRo and LtRt. Ok?
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 12.7.3 - Ram 64G - PT Ultimate 2024.3.1 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround) Last edited by yanos; 04-07-2018 at 12:56 PM. Reason: spelling |
#35
Re: LtRt AAX plugin
Antonis
I have a Dolby Surround encode /decode tdm plug for sale if you still have a tdm rig lying around Sent from my iPad using Tapatalk
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
#36
Re: LtRt AAX plugin
Have any of you tried waves DTS neural processor plugins? They do LtRt, stereo and they have also decoding plugins.
Sent from my iPhone using Tapatalk |
#37
Re: LtRt AAX plugin
Personally no I always find that what ever plugs Waves do, someone else does way better, usually because Waves imitate and make poor copies, i.e. Waves WNS and the Cedar DNS One. Sent from my iPad using Tapatalk
#38
Re: LtRt AAX plugin
I tested it. It sounds but you get a 5.1 track with four channels of silence. Not a stereo interleaved track.
For me too much workflow to get stereo and un-necessary disk space used (and you could accidentally get wrong when you select the L and R channels of the 5.1 to export a stereo interleaved wav).
#39
Re: LtRt AAX plugin
I use it with no problems at all. You just bounce a stereo sub path and your done. Its actually the same principle on Neyrinck and minnetonka.
LtRt Question | sonichead | Post - Surround - Video | 8 | 09-03-2013 01:45 PM |
5.1 to LtRt | zzstation | Post - Surround - Video | 3 | 05-25-2012 12:19 PM |
Neyrink LtRt plugin: container | lululu | Post - Surround - Video | 4 | 08-12-2011 09:06 AM |
Some LtRt quesitons | Newpostguy | Post - Surround - Video | 11 | 08-18-2010 06:08 AM |
How do i create an LtRt mix from 5.1? | Andy Hay | Post - Surround - Video | 18 | 11-08-2004 09:46 AM |
